Reasonably Priced Cold Air Indution?
Old Oct 14, 2015 | 02:36 PM
crymar's Avatar
Default Reasonably Priced Cold Air Indution?
Does anyone have any experience with the AirAid "U-build-it" cold air induction kit? It comes with a variety of tube lengths, elbows, connectors etc. at various diameters for installation into just about any car. The Crossfire throttle body has a vertical air intake which may prevent use of this kit due to limited hood clearance. Any information would be appreciated as the kit is reasonably priced.
Old Oct 14, 2015 | 02:55 PM
Mrmiata's Avatar
Default Re: Reasonably Priced Cold Air Indution?
I'd have to say silicon couplings and aluminum tubing from Ebay is a less expensive option than anything they offer.
I've just yet to see anyone post the numbers needed.. 30 deg. and 60 deg.. or two 45 deg. and lengths.. etc. Looks like about 100 bucks or so and you could be done with a single intake.
I've been looking at the Dodge Nitro intakes for maybe the Y on a dual setup.
Old Oct 14, 2015 | 03:43 PM
blasco403's Avatar
Look at this post, I listed all the parts I used to make a DCAI.
https://www.crossfireforum.org/forum...uilt-dcia.html
I have since changed out the Alum Y pipe for this silicone T.
Intake Hoses, IntakeTubing, and Intake Clamps - Intakehoses.com Black Rubber Intake Tee 3" ID
Hope this helps.
Old Oct 14, 2015 | 03:44 PM
blasco403's Avatar
Ignore, posted twice for some reason.
Old Oct 14, 2015 | 04:32 PM
ATX SRT-6's Avatar
any reason why this twin intake pipe wouldn't work?
Dual Twin Short RAM Air Induction Intake Filter Kit for Corvette C5 LS1 LS6 Jeep | eBay
Old Oct 14, 2015 | 05:29 PM
philosophico's Avatar
Originally Posted by ATX SRT-6
The space you'd need to hook that up to the throttle body is really tight on these cars, it is literally up against the firewall.
That does not look like it would clear.
Old Oct 14, 2015 | 06:02 PM
It wouldn't on an VA, but a short radius 90 deg pipe and a short 3"hose would make it fit.
HOWEVER, then there would be no place for the IAT/MAF sensor on an NA.
Old Oct 14, 2015 | 07:53 PM
ATX SRT-6's Avatar
Here's an SRT-6 with that type of Y pipe. There are several version's with different holes for the PCV hose but this shows they will fit. The link to the eBay auction is the lowest price I've found for it.
Old Oct 15, 2015 | 02:31 PM
Mrmiata's Avatar
From what I've dug around on.. the Vette intake is 3.5 dia.. the Nitro 3.7L appears to be 3" ..
Old Oct 15, 2015 | 03:08 PM
ATX SRT-6's Avatar
That's why it should work on the SRT. The ID of the TB is 74mm so the OD with the rubber gasket would be close to 3.5". If you went with 3" ID on the Y pipe the OD would be around 3.125" How would you attach that to the TB?
Old Oct 15, 2015 | 03:36 PM
Mrmiata's Avatar
Silicon coupler and 2 t-bolt clamps
Old Oct 15, 2015 | 05:19 PM
ATX SRT-6's Avatar
Do you have the stock or larger TB on your roadsters?
Also using a silicone coupler would also require more depth than clamping the Y pipe directly onto the TB.
Old Oct 15, 2015 | 05:37 PM
Mrmiata's Avatar
2 with upgraded and 1 stock.. changing that today after some logged runs.. coupler can be cut to exact flange match up between TB and Tube.. Throttle bodies have the same OD on them..
And that would be one heck of a clamp to squeeze that aluminum tubing down for a seal.. LOL. And we have to keep in mind I'm looking at N/A.. where height is a concern.
Old Oct 15, 2015 | 10:07 PM
ATX SRT-6's Avatar
I think on the photo above they cut slits into the aluminium to make it squeeze the gasket.
Do you know the exact OD of the TB offhand? I rough measured it without pulling it apart at 3.5"
Have you found the Y pipe without the filters? It seems they all come just as a kit only.
Old Oct 15, 2015 | 10:31 PM
Mrmiata's Avatar
OD at the inlet is right at 3 1/8" .. not a fan of this one.. but it is "just a Y "..
Aluminum Y Pipe Air Intake Twin Turbo Intercooler Piping Dual 3" to 3 5" | eBay
Old Oct 15, 2015 | 10:53 PM
ATX SRT-6's Avatar
Yeah, I saw those y's before, hard to tell if they would fit.
It's all kinda of confusing, this auction for a Y that supposed to fit a Nitro says it a 3.5" pipe.
Red Dual 2004 2011 04 11 Dodge Dakota Durango RAM Nitro 3 7L V6 Twin Air Intake | eBay
Old Oct 15, 2015 | 11:46 PM
Mrmiata's Avatar
Your absolutely correct.. could have sworn I read an add that stated 3 inch.. and I liked this one since you could just cap the nipple instead of dealing with the hole bored in it..
07 10 Dodge Nitro 3 7L Dual Air Intake Kit 2 Filters | eBay
Looked at so damn many.. this might be where that 3 inch thought came from.. LOL
http://www.ebay.com/itm/07-10-Dodge-...GF7A8g&vxp=mtr
kaz1961
Mar 8, 2016 04:07 PM
Helot
Aug 15, 2015 04:19 PM
waldig
Jul 29, 2015 06:54 AM
srtmodder
Jul 28, 2015 05:51 PM
Jul 25, 2015 08:01 AM
