window switches
Old Feb 17, 2005 | 12:39 AM
rpr1bob's Avatar
Lightbulb window switches
Is correcting the window switches ( reversed) a dealer warrantee correction?
Old Feb 17, 2005 | 04:50 AM
saldous's Avatar
Default Re: window switches
You can do it yourself quite easily but yes your dealer should fix it.
Old Feb 17, 2005 | 09:39 AM
saldous's Avatar
Check out:
https://www.crossfireforum.org/forum...=window+switch
You have to remove that center surround first. You just have to use a bit of bruit force, it will click then removing, don't worry you are not breaking anything, it has some grooves on the fittings to hold it in place so just pull to work them loose. Be carefull not to scratch anything though, put a cloth down etc..
Old Feb 17, 2005 | 02:59 PM
richardmyers's Avatar
If you follow the sugestions you will come to my coments. I have uploaded the pictures they refer to . It seems when the form was overhalled all the pictures I posted were lost.
Richard Myers
Xenia, Ohio
Osusannah
Feb 12, 2024 01:49 PM
Valk
Jul 12, 2021 09:49 PM
Nexxus
May 8, 2016 04:43 PM
Reliableron
Oct 17, 2015 10:19 PM
o55ie18
Oct 5, 2015 05:50 PM
