headlight aim
Old Feb 22, 2005 | 05:13 PM
Rick Woodell's Avatar
Default headlight aim
Hi guys! I knew my left (low beam) headlight aim was off, but this morning in a dense fog, I could clearly see that it is shining up and to the right. I see how to correct the up and down, but am yet to figure out how to correct the left/right aim. It's pretty bad. It isn't until you get in actual road conditions that it is apparent.
Any help will be appreciated.
Rick
Old Feb 22, 2005 | 06:59 PM
saldous's Avatar
Default Re: headlight aim
Get your dealer to fix it.
Old Feb 23, 2005 | 11:19 AM
NJspeed69's Avatar
Theres a couple of screws you can access easily to move it a little bit, then just tighten them up.
Old Feb 23, 2005 | 01:32 PM
hunt416's Avatar
The manual has a fairly good description of how to do this (pg 216). There is a "rear headlight cover" that needs to be removed in order to gain access to the aiming screws.
Old Feb 23, 2005 | 02:42 PM
JackInMidtown's Avatar
It also may be nothing more than the bulb is not properly seated. If it is not, then the aim will appear off. If you put aftermarket bulbs in, that may be your problem.
Old Feb 23, 2005 | 06:31 PM
Thanks for the info. The dealership shone them on the wall (about 6 feet away) and said they were fine. DUH! I tried to explain its a distance thing. Anyway, I'll do it myself. Thanks again.
smfrycruzr
Jul 17, 2023 05:33 PM
srtmodder
Aug 23, 2017 08:28 PM
Franc Rauscher
May 9, 2016 12:04 PM
JEFASOLD
Sep 28, 2015 12:10 PM
RacerXofFL
Sep 15, 2015 05:00 PM
