Original Air Filters and Cabin Filters In Vehicle ? ? ?
Old Sep 28, 2021 | 11:59 AM
Default Re: Original Air Filters and Cabin Filters In Vehicle ? ? ?
What kind of GREEN STUFF? The cabin filter is under the back of the glove box.
Old Sep 28, 2021 | 12:00 PM
Manuals and info here.
Index of Crossfire problems and repairs - CrossfireForum - The Chrysler Crossfire and SRT6 Resource
Old Sep 28, 2021 | 12:02 PM
copperfieldkid's Avatar
This should answer your questions - compliments of onehundred80
file:///C:/Users/Owner/AppData/Local/Temp/Cabin%20Air%20Filter%20Replacement.pdf
Old Sep 28, 2021 | 12:10 PM
Are you smelling an antifreeze odor? Depending on your brand it will be a light sweet or heavy sweet smelling odor. Green stuff coming from the air ducts (no matter what it is) is not a good thing. Check your antifreeze level when the car is cold from the radiator cap, NOT the overflow bottle. If it is full to the top of the radiator then monitor the level in the overflow bottle. Good luck!
Old Sep 28, 2021 | 01:00 PM
ray48317's Avatar
I was wrong, my wife said it was fine dirt. At the same instant the driver side vent switch to full heat while the passenger side stayed cool. Then the driver side switch back to cold. The car has fifty thousand miles on it , 2005 and a convertible. I do practically all the work on the car and did not know about the cabin filter. Here are a few pictures of what we took out of the duct from the passenger side.
Zoom in for a better view to try and identify
Old Sep 28, 2021 | 01:06 PM
nemiro's Avatar
Looks like disintegrating foam, not dirt.
Old Sep 28, 2021 | 01:18 PM
ray48317's Avatar
I agree with you. Where would that foam have come from? Any ideas?
Old Sep 28, 2021 | 01:37 PM
Foam probably coming off HVAC Cabin Filter. If filter changes are neglected (& most are by previous XFire Owners), the foam seal will start to degrade & flake off. Filter element sometimes is difficult to remove due to filter sticking to housing as foam degrades.
Cabin Filter Replacement
Old Sep 28, 2021 | 02:10 PM
ray48317's Avatar
Thank you all. I have the new filter coming in and I will replace it as soon as it comes it.
Old Sep 28, 2021 | 04:00 PM
Some time back, one of the local auto part houses was running a sale on micronAir filters that were in stock. They were unloading these at $1 each. I bought 3 of the cabin filters for the XFire & put them in my inventory.
X-fired
Dec 4, 2018 10:46 PM
Sterlin
May 10, 2018 08:50 PM
waterrat
Sep 17, 2014 03:59 PM
xodus52
22
Oct 16, 2009 08:56 PM
steverwrx
Apr 11, 2007 07:14 PM
