2004 Crossfire no cranking but fan running
Old Sep 2, 2016 | 12:53 AM
REYMARTZ's Avatar
Default 2004 Crossfire no cranking but fan running
Car doesn't crank but fan runs really fast once I turn key all the way. Battery is fine. Coolant and oil is good.
I waited for car engine to get cool and it cranked right up. This happens very often.
I read other threads that it can be the K40 module or relay fuse. Where can I find the k40 module?
Can someone please let me know how to fix this?
Old Sep 2, 2016 | 09:00 AM
Default Re: 2004 Crossfire no cranking but fan running
Look at 'How to repair the relay control module' it was added to today, look at the first post in it.
The fast fan may be the fan control module failing. Fix the RCM first though.
Add more details of what went wrong first, full info makes it easier to solve or at least get relevant ideas as to the problem.
Old Sep 2, 2016 | 04:04 PM
tighed1's Avatar
It's the Engine Control Relay in the RCM.
Email me tighed1@hotmail.com and for $27 I'll replace the relay along with the air pump relay. Solder bad joints and give ya the Me So Horny mod (horn works without the key).
Old Sep 2, 2016 | 04:40 PM
Yup, you are powering up the Fan Module but not the ECM, so the Fan Module is going into Emergency Mode as it was designed too.
Fix yer RCM or send it to DJ (Post 3) and he will fix it for you.
Old Sep 2, 2016 | 06:43 PM
Where is this mentioned in previous posts? Did I miss it?
Old Sep 3, 2016 | 12:09 AM
Dave, first sentence, post 1.
As soon as you turn the key on, the FCM is powered up. If it does not see the "are you there?" pulses from the ECM, it goes into emergency mode and runs at 100% speed.
IF the output from the engine control relay is not there to power up the ECM, the ECM does not send "are you there?" pulses to the FCM and it does not send the enable to the pulse module to engage the starter. Resoldering the RCM or changing the relay on the RCM (depending on if the relay is bad or the solder connections are bad) fixes all of this.
Also:
There is a constant handshaking going on between the FCM and ECM. If the FCM does not see the pulses from the ECM, it goes into emergency mode. If the ECM does not get it's handshakes from the FCM, it lights the "low coolant" light.
Old Sep 3, 2016 | 07:15 AM
Just an additional note on this "fan runs full speed" thing :
If the IAT sensor is faulty or unplugged on an NA, the engine will start and run, but the fan will crank up to top speed also. You will also get a CEL - don't remember the P code, I just cleared it out.
Ask me how I know this
Old Sep 3, 2016 | 10:41 AM
And is it true that the IAT sensor is integrated in the MAF sensor?
Old Sep 3, 2016 | 12:07 PM
I wanted to know where the cause of the symptoms appeared on the forum before.
Have the cause been taken from the Mercedes forum or what?
Old Sep 3, 2016 | 12:22 PM
Well, I got my explanation from grabbing an oscilloscope and probing that line from the ECM to the FCM and figuring out that they were using a pulse width modulation technique to tell the FCM what speed to run the fan. (The FCM also uses PWM to vary the fan speed - but that's not the point here.) (This after Rudy told me part of it, back in 2009 - I then started my own investigation cause I can't NOT know!)
I could see the pulses going back and forth during times when the ECM was not telling the fan to run at all - you could easily see the handshake.
Old Sep 3, 2016 | 12:26 PM
Hit the button too soon...
Anyway, it was obvious to me what was going on, I'd cut the wire and the fan took off and the light came on. It was only a matter of measuring the width of the pulses to figure out what they were doing. I could see the pulses from the ECM get wider when I turned the A/C on, then even wider as the temp needle went past 1/2 way.
I then used a function generator to simulate the ECM to make the FCM do what I wanted - THAT was a challenge.
But then the performance shop in ATL charged me only $50 to reprogram the ECM for a lower fan-on temperature. I then stopped by research into how to have a "dial it up on the dash" fan speed.
Old Sep 3, 2016 | 12:53 PM
Yes, that is true.
Old Sep 3, 2016 | 12:54 PM
You lost me when you said oscilloscope, so I'll have to take your word for it.
What I have intended to do for a long time is to start a thread where all the known problems and their solutions are listed, then they can be put in the Crossfire problem index. They would all be combined in a .pdf format, whoever writes the post will get full credit of course. Just a simple list of symptom(s), and repair, nothing fancy just keeping to the straight facts. Just gimme the facts as Joe Friday would say.
We have all these answers spread all over the forum and some are hard to find and the questions are asked over and over again.
Does that sound feasible?
You can copy someone else's post, just give due credit so that both can be credited.
Old Sep 3, 2016 | 12:59 PM
Ever see one of those old Heathkit troubleshooting charts ?
It is a kinda reverse bubble flow chart that starts with "I have a problem", then leads down through different boxes with various paths leading out of them as defined by the description choices in the boxes like "engine", "body", "brakes" etc.
Maybe that would be an idea ?
Or not.
Old Sep 3, 2016 | 02:17 PM
What I have intended to do for a long time.........Does that sound feasible?
Reasonable to say the least.
Or not.
Hmmm. I'm thinking I like that idea as well.
Old Sep 4, 2016 | 03:51 AM
tighed1's Avatar
In the past I was encountering RCMs that didn't start and the fan would spin up. Never took the time to figure it out (sent RCM back to owner with an apology). It bugged me for quite sometime so one day I decided to find out why it was happening. Been fixing that issue ever since.
First time I think I actually mentioned it was here.
https://www.crossfireforum.org/forum...tml#post866312
Old Sep 4, 2016 | 08:41 AM
Just like the RCM poorly soldered joints, which they solved ten years ago CLICK, this problem was sorted on SLKWorld.com forum six years ago.
CLICK
Took me ten minutes to find the solution when I had the symptoms.
Old Sep 4, 2016 | 11:55 AM
tighed1's Avatar
And you didn't tell us about the solution because??
Sounds like yer accusing me of claiming credit for a solution, again.
Both times you pointed this out my work was my own. Wouldn't have spent the time and effort figuring things out had I known the solution was already out there. I suppose there is lot to learn on some of the MB sites as our car are similar.
If it makes ya feel better Dave, here's this:
"I tighed1 hereby give all credit for the Mystery No Start and fan running at high speed (no start) solutions to the good folks that discovered them on other forums, prior to my discovery of the same issues."
Feel better now?
I suppose that since I actually have a "real" Mercedes now I should frequent those MB sites too lol!
Old Sep 4, 2016 | 06:56 PM
Feel better now?
Touchy, touchy. You are reading something into it that is not true.
If you read this thread you will find that I only learned the symptoms on the 2nd of this month. I did the search of the SLK forum today and I soon learned, in 10 minutes, that the cause was what you and PizzaGuy said they were.
In both cases I have said that the solution had been discovered years ago on the Mercedes forums and they all come to light in a single thread started by Bazzle from Oz on the RCM solder issue and another guy on page three of the high speed fan/no start issue.
You took offense at the RCM post, at that time you said they should have told us years before you/we found out.
