Too Low Idle
Old Sep 6, 2017 | 07:42 PM
spoiler's Avatar
Default Too Low Idle
Lately and sporadically, my car will shake slightly and almost die while at while at red lights. When I give it gas, it hesitates and fills as though it will die. This can be avoided by giving it gas while in neutral or in drive with a foot on the brake.
Old Sep 7, 2017 | 01:16 AM
JSK's Avatar
JSK
Default Re: Too Low Idle
I vote for sending your RCM to tighed1 for repair. Solved the same symptoms for me.
Old Sep 7, 2017 | 04:53 AM
daveesrt6's Avatar
Hmmm , i remember last summer here once or twice in traffic my 6 did the same thing .
It has not done it since and i put it down to dodgy fuel .
Good to hear it was the RCM , probably shows its fault in the heat . ( it was a stinkin hot day when my CPS failed , in the middle of fing nowhere ..)
I have a brand new RCM i carry in the trunk ...and spare CPS !
Old Sep 7, 2017 | 08:49 AM
Could it be because low fuel pressure does not allow metering of a small shot of gas. Does it do that when the engine is cold and a rich mixture is called for?
I had something similar once on another car and never could find the cause, finally I had it in the dealership and the mechanic checked the fuel pump, the pressure was way down. TaDa problem solved.
Old Sep 7, 2017 | 09:11 AM
spoiler's Avatar
tighed1...a member?
RCM?
I changed the CPS after I purchased it two years ago in order to pass the smog test.
On Monday morning (75 degrees), it happened at the first red light, the car sat in a parking lot for 12 hours then it did not happen on the way home.
I have been using regular gas here at 5000' in Colorado since I purchased it.
Old Sep 7, 2017 | 09:35 AM
Steve Jr's Avatar
Originally Posted by spoiler
tighed1...a member?
RCM?
tighed1 is a member.
RCM= relay control module.
An regular gas is a BIG problem. These cars are DESIGNED to run on high octane. 91 or higher. I run 93 from Shell.
Old Sep 7, 2017 | 12:09 PM
JEFASOLD's Avatar
Amen to that! My car never sees anything below 93!!
Old Sep 7, 2017 | 07:31 PM
spoiler's Avatar
What elevation are you guys at? I heard that elevation equals a lowering in octane requirements. I have not had an issue with performance or anything else since I bought it.
Old Sep 7, 2017 | 07:39 PM
spoiler's Avatar
I searched for RCM and found the thread that has been ongoing since '09 but it concerns not starting. I admit, I only read the first and the last thread. Is there a thread devoted to my idling issue?
Old Sep 14, 2017 | 09:24 AM
spoiler's Avatar
I sent the RCM off to DJ. Almost having the car die at intersections was just too nerve racking!
Old Sep 14, 2017 | 11:11 AM
Kingdav1954's Avatar
Read up on the map sensor and how it works May shed some light on your low idle problem especially at 5000 ft.
( Manifold absolute pressure sensor)
Using using the search bar type in map or maf then hit search and when it comes up go to Post Number 3 and it will show you a picture of the map sensor and where it's at. Also there's an excellent article on how it works on Wikipedia.
Old May 20, 2018 | 01:11 PM
spoiler's Avatar
The issue was getting worse as it happened while backing out of the driveway among other places not including intersections. Added a can Kano Kreen to a full tank of gas and it may have solved the problem!? The low idle has not occurred the last few times that I have driven it.
Old May 21, 2018 | 09:29 AM
spoiler's Avatar
Yesterday, at an intersection, it shook until I put it in neutral.
Time to research MAP Sensors!
Old May 23, 2018 | 12:39 AM
See if any codes have been set. Why pay for a car that can possibly give you a heads up on the problems.
