Key fob not working
Old Dec 13, 2018 | 12:08 PM
Crossfire1993's Avatar
Default Key fob not working
Hey guys my key fob just stopped working. I replaced the battery and still no. I don’t know if maybe it needs to be reset or re activated. Any solutions on how to do that or who to get in contact with? the dealership is asking 300$ to fix
Old Dec 13, 2018 | 01:06 PM
Default Re: Key fob not working
Check again, the direction of the batteries (and 2 each). Then you have to make sure the FOB is sync'ed to the car for the doors to work. Do a search on how to do this, maybe 'sync key fob?' Am wondering if the FOB worked before changing the batteries? Good luck on this issue.
Old Dec 13, 2018 | 02:16 PM
Insert key in ignition.
Turn to "on" (not accessory)
Press either button twice.
Turn key off, remove and test function of lock/unlock.
Then, send me the $300.
Old Dec 13, 2018 | 02:27 PM
maggy55's Avatar
If nothing works , you might try disconnecting you car battery for a few minutes, then reconnect it. If the remote is bad, you can get used ones on ebay and reprogram them , but you have to move the rfid chip from your current remote to the new one.
Old Dec 13, 2018 | 03:12 PM
yes it was than it just randomly stopped so o replaced the battery and still no 🤷*♂️😩
Old Dec 13, 2018 | 03:13 PM
lol I’m going to give it try and see if that works thanks
Old Dec 13, 2018 | 03:44 PM
If the batteries die and are not replaced pretty quickly the memory in the fob fails and needs to be reset as described.
Pressing the open or the close button from too far away from the car will require the fob to be reset.
Old Dec 15, 2018 | 07:26 PM
blackcrossfire07's Avatar
If the battery in the key fob goes bad, will you have trouble starting the car? I am having issues starting the car after it has sat for a couple weeks. The battery on the car is great. The engine turns and turns but it won't start. Once it starts the car runs great and will start up every time. Just wondering if maybe my battery in the fob is the problem. I owned the car 14 years and I don't I ever replaced it.
Old Dec 15, 2018 | 07:27 PM
And it is good to see you are still hanging around one hundred!
Old Dec 15, 2018 | 07:29 PM
That is a tidbit from the manual that far too few of us know about.
I am convinced that has caused some of the odd little issues over the years.
Old Dec 15, 2018 | 07:33 PM
Originally Posted by blackcrossfire07
If the battery in the key fob goes bad, will you have trouble starting the car? .
No. The battery-operated transmitter for the lock/unock/panic functions is one thing.
Once you insert the key and turn it to "ON", the SKREEM powers up and energizes the ring around the key, energy is radiated to the RFID chip in the key, the RFID responds with a TINY RF (radio) signal, that has a code in it the SKREEM uses to know that the key is authentic. Power for this function, again, comes from the antenna ring.
Old Dec 15, 2018 | 08:44 PM
Do I have this right Mark ?
There's AM, FM, VHF, UHF and now TINY RF. Is that a NASA rocket science thing ?
Old Dec 16, 2018 | 12:01 AM
Now quite - this is how it is:
AM and FM are modulation techniques. (As are CW, FSK, C4FM, LSM...)
VHF and UHF are wavelengths. (As are LF, MF and HF (known as shortwave), Microwave...)
But............
TINY is a signal level. (It goes like this: imperceptible, tiny, very very weak, very weak, weak, moderate, strong, intense and bodacious* )
*1970's era CBer's came up with "bodacious" as applied to signal levels.
Old Dec 16, 2018 | 12:09 AM
JSK's Avatar
JSK
It is amazing how many tidbits of knowledge I gain from this site.
Old Dec 16, 2018 | 12:29 AM
But............
10-4 good buddy. Keep the shiny side up !
Old Dec 16, 2018 | 01:12 AM
Hindin's Avatar
Smile Re: Key fob not working
Okay, I'll bite. How big is a tidbit?
Old Dec 16, 2018 | 06:42 AM
Will fit between a scosch bit and a tiny bit
Old Dec 16, 2018 | 09:14 PM
Hindin's Avatar
Got it. So it's a scosch bit, tidbit, tiny bit, bit, bigger bit, biggest bit, and bodacious bit. Thanks
Old Dec 16, 2018 | 10:14 PM
But when does a bit become a byte?
Old Dec 16, 2018 | 10:42 PM
Whenever a Corona gets it's lime.
