2004 Crossfire No brake lights
Old Apr 25, 2019 | 08:41 PM
Lantzj22's Avatar
Default 2004 Crossfire No brake lights
Hi everyone I’m new to the group! I recently purchased a 2004 crossfire with tons of issues and I’ve been able to conquer all except one. The brake lights just won’t work. I replaced the brake switch. The relay. The 50 amp fuse. Checked the bulbs themselves and the 3rd brake light won’t illuminate as well. So I’m stuck anything helps! Thanks!
Old Apr 25, 2019 | 09:00 PM
Default Re: 2004 Crossfire No brake lights
Check fuses and output from the illumination module.
Old Apr 26, 2019 | 01:20 AM
I am hoping you have downloaded the online service manual (showing wiring diagrams and component locations)? After checking the fuses in the illumination module located between the door and inner dash area, check the next thing. A step not mentioned is take a voltmeter and open either brake lamp bulb assemblies to see if you have the 12V present at the bulb socket when the brake pedal is pressed. If the 12V is there when the pedal is pressed, you have a ground out. Lookiing at the wiring diagram, you can see the color codes for the grounds (brown) in the lower left corner (3 wire runs) used for the voltage test, and the ground wire drop points. Good luck finding this if it is a ground problem.
Old Apr 26, 2019 | 11:37 AM
funny,, you would never think that the RCM would only make your brake lights not work but it does sometimes i have posted this before,, it happens in the 04 more than the others jim
RaymondHerrera1
May 24, 2018 07:18 AM
AlexParra
Nov 4, 2015 08:53 AM
mthtulsa
Aug 3, 2015 06:14 PM
Adrian_X
Jan 10, 2013 04:23 PM
DrakeBeery
Oct 25, 2011 01:39 AM
