Cruise control will not work while lights are on
Old Nov 7, 2019 | 07:56 PM
chargerwayne's Avatar
Default Cruise control will not work while lights are on
If the lights are on the cruise control won't turn on. If you turn on the lights while the cruise control is working it immediately shuts off. Any suggestions on where to look? I am thinking wires are shorted somewhere in the harness.
Old Nov 7, 2019 | 08:25 PM
Default Re: Cruise control will not work while lights are on
Be sure all your rear lights are working properly. Possibly a filament problem in a bulb.
Old Nov 7, 2019 | 09:08 PM
What the two systems have in common is the Stop Light Switch.
Old Nov 7, 2019 | 10:45 PM
Ditto, might be that brake switch.
Old Nov 8, 2019 | 12:30 AM
JSK's Avatar
JSK
Check that the tail lights are properly grounded.
Old Nov 10, 2019 | 01:40 PM
Thank you everyone for your help. I put new bulbs in the. Brake lights and the cruise works perfect!
Old Nov 10, 2019 | 08:53 PM
Was it a burned out bulb? If not why wasn't the lamp out bulb on the dash lit then?
Old Nov 10, 2019 | 10:48 PM
If a filament of the tail light would break and fall against the filament of the brake light, it would power the brake light, and also back feed the circuit to think the brakes are being applied, not allowing the cc to work. I saw this years ago when a vehicle wouldn't go into lock-up because the ECU thought the brake was being applied. When you apply the brake, the transmission would come out of lock-up so the car wouldn't stall.
James
Old Nov 11, 2019 | 02:54 AM
James
Wow, absolutely wild! Once in a million fault? I couldn't even have guessed... Amazing...
AMonte28
Sep 12, 2014 01:50 PM
Louie K
20
Jul 14, 2011 11:27 AM
tommy_8701@hotmail.com
Apr 3, 2011 09:59 PM
Infinite
Nov 4, 2010 08:06 PM
Tony Curtis
Nov 4, 2008 06:14 AM
