2004 Chrysler Crossfire will not turn over
Old Feb 17, 2020 | 02:23 PM
Tez's Avatar
Tez
Default 2004 Chrysler Crossfire will not turn over
Key turns to start position but will not fire .... first two time you hear a click each time then silence... third time you get nothing and all accessories turn off until you take key out and restart process
Old Feb 17, 2020 | 02:27 PM
Default Re: 2004 Chrysler Crossfire will not turn over
Sounds like a really low battery along with a SKREEM issue
Old Feb 17, 2020 | 05:42 PM
Tez's Avatar
Tez
........ I had the battery checked at auto zone
Old Feb 17, 2020 | 06:23 PM
maggy55's Avatar
Rcm ?
Old Feb 17, 2020 | 08:20 PM
Tez's Avatar
Tez
Originally Posted by maggy55
Rcm ?
haven’t check yet wanna try starter first ... where is it located?
Old Feb 17, 2020 | 08:32 PM
I've been a member here eleven years. Owned three Crossfires - several people have replaced starters only to find it was not the starter.
RCMs cause "no starts" so often, we have a thread dedicated to fixing them, but if you are good with throwing money and time away, crawl under the car, passenger side, back by the "bell housing" and you will find the starter.
From what I read in your post, it is either the RCM or SKREEM. I can't tell you which, as you imply the starter never even engages - that is an RCM issue. But you then say you hear it twice, then nothing, THAT is a bad SKREEM. But again, you won't just hear a click, you will hear the starter engage, this will happen twice, third time, you get nothing. Yank battery cable and reconnect it, you get two/three more tries then nothing.
If the starter NEVER engages and turns the engine over, it sounds to me like a bad RCM.
If you REALLY are hearing a click - is it coming from the top of the engine or the starter solenoid? If solenoid I might suspect starter, but I'd be more interested in watching battery voltage as well. I sharp did in battery voltage will cause the ECM to "kick out". In these cases, you simply have a bad battery or REALLY corroded/loose battery cable connection somewhere.
I can't tell from your post exactly what you are chasing.
Old Feb 18, 2020 | 01:15 PM
Tez's Avatar
Tez
Here
Old Feb 18, 2020 | 03:44 PM
Here
Here? Here here?? Errr, what?
Old Feb 19, 2020 | 09:21 AM
Tbirdtony's Avatar
Tez - I believe that you have a bad battery. I had the same issue 2 months ago. I had AutoZone check my battery. It passed the load test but showed that the battery only had 50% capacity. They charged it and it passed the load test but still showed that the battery only had 50% capacity and my engine still didn't turn over. I purchased a new battery and my Crossfire has been fine ever since. Really look at the battery. Hope this info helps.
Old Feb 19, 2020 | 10:37 AM
rayludwiczak's Avatar
Agree have battery checked first. If problem still exists see video on internet crossfire RCM repair. Easy fix and know crossfire problem.
Karl Von
Oct 26, 2022 11:17 AM
kjf5
Jul 29, 2018 07:38 PM
Fastcars__only
May 31, 2016 09:57 AM
Thomas Lewellyn
18
Apr 23, 2016 12:09 PM
TexasHighRoller
Jul 28, 2014 04:48 AM
