A little help…
Old Nov 24, 2021 | 08:11 AM
jasonk931's Avatar
Default A little help…
I must confess, I am not a mechanic. I have a 2006 crossfire six speed. Since it has gotten colder over the last month, I notice, when I come to a stop, my car is still idling very high before it finally settles down after a couple of seconds when I come to a stop. Can anyone direct me to the cause of this? I hope that my description makes sense. I checked all my fluids and they seem to be in order, so I’m wondering if it is mechanical or just needs a tuneup?
Also, the Crossfire recommends Pentosin CHf-11s fluid for the steering. Will standard steering fluid work as well?
Old Nov 24, 2021 | 09:39 AM
Default Re: A little help…
1) Try this:
Warm engine up.
Put in neutral, set brake.
Raise hood.
Wait for engine to stabilize, (you said it stabilizes after a bit...)
Now, yank oil cap off.
..If the engine surges and idles erratically, good.
...if the engine does not react to the yanking of the cap, you have a hell of a vacuum leak. Fix it.
2) No need to use the wrong fluid, Pentosin is available everywhere.
3) The only "tune up" you can do is: replace air filters, replace 12 plugs, replace 12 plug wires, and maybe replace the crank sensor. If the car is near 100,000 miles, I'd do that anyway. I was having misfire and O2 codes like crazy around 96,000 with my Graphite and I changed all 12 plugs/wires and ALL of the trouble went away. Car ran way better, too.
Old Nov 24, 2021 | 11:04 AM
jasonk931's Avatar
1) Try this:
Warm engine up.
Raise hood.
Thanks for the help and the tips!
Old Nov 24, 2021 | 01:23 PM
jasonk931's Avatar
1) Try this:
Warm engine up.
Raise hood.
Popped the cap and the engine surged erratically as you said. Checked all my fluids and they are solid. Any other factors? I have had the plugs changed a few months back. Was running tops then.
I might take it to Chrysler and have them run a diagnostic.
Old Nov 24, 2021 | 01:59 PM
See my sigline. Don't throw money away like that.
Old Nov 24, 2021 | 05:46 PM
DO NOT GO TO CHRYSLER! IF you must take it in for work you cannot do find a European mechanic that works on MB SLK-320's. You'll get a huge bill with no help if you go to Chrysler (stealerships).
Old Dec 2, 2021 | 08:53 PM
Goldwing's Avatar
Make sure the cover that contains the air filters is properly seated all the way around, especially at the rear. I think that is where the MAF is. I am pretty good at this stuff but the last time I checked the air filters I failed to replace the cover properly and after a short time it started running like crap.
TheThomaswastaken
Jun 22, 2023 03:18 AM
J.J.
Sep 11, 2017 07:40 AM
racehorse
May 20, 2010 07:04 PM
marcossaito
Jul 22, 2009 03:34 PM
dhedhunter
Mar 6, 2008 08:40 PM
