How to open fuel door manually as security system wont open it?
Old May 4, 2022 | 08:02 PM
jcbigbot's Avatar
Default How to open fuel door manually as security system wont open it?
Need some help
Old May 4, 2022 | 10:16 PM
dcskmail's Avatar
Default Re: How to open fuel door manually as security system wont open it?
I found this by doing a search in the threads upper right corner of home page. Also someone said to make sure the car is unlocked and that may free the fuel door , if that fails here's another option: the gas cover are opened and closed from the air tube coming out of the central locking pump. when i bought my crossfire the central locking system wasnt working and i was in the exact same spot as you. you have to open the trunk and remove some of the covers of the gas side and put in your arm between covering and the bodywork of the car. next to the gas is a level you can pull to manually open.
look at the picture. you need to find the red part by feel:
https://www.crossfireforum.org/forum...chanism-72.jpg
Old May 4, 2022 | 11:11 PM
jcbigbot's Avatar
Thanks for the info !! Some how I will have to **** into the trunk area as I can only open the drivers door with the key !!!! Thaks again !
Old May 5, 2022 | 09:16 AM
You can open the trunk by using a screwdriver in the hole left when the drivers side license plate light is removed. There are posts showing how that is done.
Old May 7, 2022 | 06:47 PM
jcbigbot's Avatar
Thank you for your help !!!
Old Jul 21, 2025 | 03:18 PM
ja021h57's Avatar
Thumbs up Re: How to open fuel door manually as security system wont open it?
Good evening. Thanks for the information, I really appreciate this!
Germany
Aug 27, 2012 07:06 PM
Stan Soroken
Apr 13, 2010 11:52 PM
amusedpen
Apr 24, 2009 09:09 AM
dobro
Aug 5, 2006 04:33 PM
mouserider
Jul 26, 2003 11:47 PM
