Break pedal problems
Old Apr 6, 2023 | 07:39 PM
CurtCrossfire's Avatar
Default Break pedal problems
2006 coupe manual
I was driving along and noticed the break wear indicator coming on when I pressed the break, after a while I pressed the break and it almost went to the floor, it still stopped the car but usually the break is stiff and feel a lot of resistance but now it’s really light, so I had the front breaks changed and the wear indicator no longer comes on but the pedal still goes to the floor, when I’m slowing down I pump the break pedal a few times and it goes back to normal but after that it goes to the floor again, I’m at the point anytime I need to stop or come to traffic lights I need to pump the pedal 2-3 times for the break to work correctly, any ideas what this is and how to fix?
it’s had new break pads on the front.
no leaks or cracked lines and break fluid is at the correct level.
thanks
Old Apr 6, 2023 | 09:29 PM
Default Re: Break pedal problems
First step is to have all 4 brakes bled and adding new fluid though out the system. James
Old Apr 6, 2023 | 09:32 PM
Hi James, I will give that a go later today, any idea what size pipe fits on the bleed valve? Thanks
Jun 4, 2019 12:04 PM
crazyfred
Apr 28, 2018 01:05 PM
BibaResto
Nov 30, 2013 10:50 PM
smokey847
Jan 5, 2013 03:00 AM
blackxfire
Oct 8, 2007 02:54 PM
