Closing Door?
Old Sep 14, 2005 | 03:02 PM
kmag50's Avatar
Default Closing Door?
Have been noticing that when I shut the passengers door sometimes the window gets "hung up" with the upper rubber molding and stick out a little bit. Then I have to re-shut the door to get the window to flush up where it should be. Anyone else having that problem? Seems to me that DC should have had the window automatically drop everytime the door is opened...like the T-bird does.
Old Sep 14, 2005 | 03:41 PM
former NXMX5's Avatar
Default Re: Closing Door?
there was a TSB out for this IIRC... i manually adjusted my window track because i had similar problems shutting the door, but mine was the drivers door. if you remove the rubber grommets from the bottom of the door, you should be able to adjust the window track. i ended up removing the door panel for mine.
good luck --
Old Sep 14, 2005 | 10:25 PM
chxf's Avatar
TSB 23-004-05 "Door Glass Misalignment Or Contacts The Roof". Hope this helps.
Old Sep 15, 2005 | 09:15 AM
kmag50's Avatar
Thanks for the TSB....I appreciate the help...will look into it with my dealer.
Osusannah
Feb 12, 2024 01:49 PM
Valk
Jul 12, 2021 09:49 PM
Billy22Bob
Sep 28, 2015 08:08 PM
Sep 25, 2015 02:16 AM
eatmycrackers
Sep 23, 2015 09:08 AM
