Passenger Grab Handle
Old May 31, 2025 | 03:42 PM
WTS's Avatar
WTS
Default Passenger Grab Handle
The Crossfire Coupe does not have a passenger grab handle, and with the handling ability of this vehicle probably should have one - anyone install a third-party handle or have any other recommendations?
Old May 31, 2025 | 05:38 PM
DeKalb's Avatar
Default Re: Passenger Grab Handle
What is your definition of a "grab handle" ... it should have a passenger door pull handle to close the door
Old May 31, 2025 | 05:49 PM
WTS's Avatar
WTS
Yeah, the door pull handle can suffice for support, but I'm more thinking of the usually above the window mounted grab handle
Old May 31, 2025 | 05:53 PM
DeKalb's Avatar
I have not seen a handle in that location ... but that's not saying it can't be done ... Google and see what you find
I Know for sure my Roadster doesn't have one ...
Old May 31, 2025 | 07:00 PM
WTS's Avatar
WTS
Yeah, if a roadster were to have one it'd be on the A pillar, which sometimes has one. I've found some handles on Amazon which use screws to attach to drilled holes, which seems somewhat iffy, but it might work and be strong enough
Old Jun 3, 2025 | 01:55 AM
If you install one, make sure you go into metal. That plastic isn't going to hold up and if any really pulls on it, any trim piece will likely come off or break.
Old Jun 3, 2025 | 09:16 AM
copperfieldkid's Avatar
The passenger door handle should be sufficient. Clearly either a pillar or above the window mounted grab handle would have been both a desired and useful feature.
Old Jun 3, 2025 | 01:34 PM
Goldwing's Avatar
Not a good idea to drill through the roof to install an "oh ****" handle.
Old Jun 4, 2025 | 02:41 PM
Root66's Avatar
A passenger grab handle would not only be useful for "spirited driving" but also for entry and exit for aging passengers. A pair of proper threaded receptacle in the A" pillar like a Riv-Nut would allow a sturdy handle to be attached.
taschwen
Mar 16, 2025 09:35 PM
brandoni
Oct 31, 2015 08:50 PM
Squirrel Crusher
Dec 10, 2009 11:05 PM
spensley
Feb 4, 2008 02:11 PM
