Jacking up the car?
Old Nov 4, 2005 | 10:28 AM
MI Roadster's Avatar
Default Re: Jacking up the car?
Glad it all worked out. Is the sensor working ok?
Old Nov 4, 2005 | 10:33 AM
danimal's Avatar
Originally Posted by HDDP
I thought the SITCOMS I worked on were funny, but that's hilarious...
You're right!!! A little scary too...
Old Nov 4, 2005 | 10:23 PM
onefortypointsix's Avatar
Well, the tire holds air now, but the tire pressure sensor light won't turn off. I haven't checked the owner's manual yet. Any ideas?
Old Nov 4, 2005 | 11:57 PM
RickB's Avatar
Did the dealer reset the TPMS section of the computer?
Old Nov 5, 2005 | 01:24 AM
Nope. I dropped off the tire at the dealer. I'll take it in on Monday. Thanks!
Old Nov 5, 2005 | 09:14 AM
typhoon55's Avatar
That's the problem with the TPMS ...
If you change out a tire - trip to dealer to recalibrate,
if you have a faulty battery - trip to dealer.
There must be a way to recalibrate without dealer or the thing is not worth the hassle.
Old Nov 6, 2005 | 11:03 AM
greenie's Avatar
I know that the dealer uses a magnet to reset the sensors in the wheel. I don't know if there is anything else involved.
Old Dec 28, 2007 | 03:41 PM
JonZoidberg's Avatar
Help! I got a 2 ton jack and jack stands but I don't know how to use both! I jacked up the passenger side by the front jack point and it lifted the rear tire too, but I don't know where to position the jack stand so I can lower it down. I looked under with it jacked up and I can't decide where to put the jack stand. Better still, I'd like to know where to jack it up so I can put the stand on the jack points. Is there one location we can jack up the entire front end and put two jack stands under the 2 front jack points?
Old Dec 28, 2007 | 07:26 PM
HDDP's Avatar
Use the jack point that is along the rocker panel and raise the car... slide the jack stand under the car to where you see a flat 1"x1/4" bar that attahes to the frame joist... The flat bars run diagonally and is joined to the left and right frame joists with a 10mm bolt... This is where you should place the jack stands on both sides... Hard to explain, but it looks like an X with a bolt in the center... This is the subframe of the car and is the strongest point... They are located on both the driver and passenger sides about 12" in and 12" aft of the front wheels...
As far as the rear, place your jack stands directly under the rear A arm connection bolts (junction) that attach your rear wheels to the frame on the inboard side... this point is appx. 12" inboard of your rear wheels and is impossible to miss since it has a big A S S bolt...
Then drop your jack and run like hell Hope this helps... If you have any problems understanding the convoluted directions, I'll shoot some photos for your to follow...
Old Dec 28, 2007 | 10:45 PM
I'll give that a shot next time, thanks. I'd seen someone else say to jack up close to the wheels and then put the stand at the jack points. I didn't want to try that since the front suspension is independent and I thought that might put too much stress on it. I finally said what the hell but I found I couldn't do it anyway because my floor jack doesn't have enough clearance to actually pump it when it's that far under the car.
By the way, thanks for the speedy response! but in the meantime I borrowed a pal's ramps and after chocking them with some 2x4's against my garage wall, I put it up on the ramps, chocked the rear wheels, and did my first oil change. I'm glad the bottom 6 inches of my garage wall is concrete. So, in about 7000 miles I'll give it a go. However, I wonder would the jack stands there get in the way while I'm changing the oil?
I guess I'd feel as comfortable under 2 jack stands and well chocked rear wheels as I would under anything else. I guess I could throw some lumber under there too, but it's not necessary. I do believe in the idea of sticking the spare under the car when in a pinch, however.
I'm glad I've decided to change the oil myself, the last guy who did it cranked the drain bolt all to hell. I came and checked the forum to see if I had missed where it said that it was backwards and loosened to the right. I had to wrap a pot holder over the socket because my hands were getting too sore from pulling. I finally was able to break it loose. Doesn't need to be so tight.
Old Dec 29, 2007 | 05:01 AM
stlouistrucker's Avatar
I put it up on the ramps, chocked the rear wheels, and did my first oil change. .
JonZoidberg - Were you able to get all of the old oil out when it was up on the ramps?
Old Dec 29, 2007 | 12:09 PM
Probably not. I would have preferred to use the jacks so I could have lowered it during the drain. When I filled the oil bottles I did get 8 quarts, minus what stayed in the drip pan. So I'm confident I got almost all of it. The ramps almost touched the bottom of the front end before I drove up on them, so the front end wasn't lifted too much. It was just enough room to get under and get to work.
victorlautreamont
Jun 29, 2017 01:22 AM
mhajek18
Dec 30, 2015 03:40 PM
BibaResto
Jul 4, 2015 03:20 PM
Geechee1962
Jun 29, 2015 09:15 AM
ardenian
Jun 6, 2015 09:28 AM
