Rotex Gold Brake Pads
I know this has been discussed before. I did the search but couldn't find answer to my question...which is this:
From reading the forum, I understand that a hole must be drilled into the Rotex Gold pad for the sensor to fit through. Where is the best place to get these pads...and...it there a brand Rotex Gold pad that you don't have to drill?
Thanks!
P.S. Andrew, I found through the search, your detailed instructions on installation.
Great
Thanks!
Mine were pre drilled. I got them from brakeworld.com? I would do it again, they stop good and lots less dust.
I had problems with there web site so they called me to figure out what I wanted. Nice people.
Another reason I love this forum.
I say go for it. It is as easy as any other front brake pad replacement, nothing tricky here.
When I say it was noticeably less dust, that is an understatement.
I wouldn't have believed it if I didn't see it myself.
I don't think that is because the rotex are that clean, it is because the factory ones are that dirty.
Also, I read some where on this forum (can't find it now) that there is a reason these aftermarket pads won't wear down the rotors faster than the OEM ones. Can someone enlighten me, please? Or, do I have that all wrong?
Also, did you all replace your pads for all 4 wheels or just the two fronts as they are by far the dirtiest?
This is a much better choice IMO and should come with new brake sensors...
http://www.tirerack.com/brakes/brake...ted&perfCode=P
Originally Posted by HDDP
Cissy: The hole is really simple to drill, don't feel intimidated by it... It's just a small guide hole... I'll show you via photos if you like...
Nope... They're like $80 and come with new brake sensors, which if bought from your dealer separately would add about $7... I think what you're looking for are LOW DUST pads... Any ceramic pad will be considered low dust... Don't get me wrong, Rotex is a good one as well...
And since the Akebono pads come with their own sensors, you won't have to drill a hole...
HDDP Knows his stuff, but are the ones your talking about race pads?
I only changed the fronts to the rotex gold, as did most of the other rotex users.
And since the Ackebono pads come with their own sensors, you won't have to drill a hole...
it's very simple... when you remove the OEM pads (inboard), you'll see a little guide hole that the tip of the brake sensor slides into... if your new pads don't have that guide hole, just drill one into it...
I'll post a picture in the next few hours for you...
This might help:
https://www.crossfireforum.org/galle...cat/500/page/1
This might help:
This might help:
This might help:
CISSY: I haven't even posted the picture of the guide hole yet... That was just the sensor attached to the pad... Gosh darn it... Now I have to go down to the garage and shoot the picture... BRB
