How to spin tires with Automatic?
Old Sep 8, 2006 | 02:25 PM
wkdgood's Avatar
Default How to spin tires with Automatic?
Hi All,
My 11 year old nephew wants me to lay down some rubber. Problem is with 2005 Limited with Auto I am not sure what is the safest way to do this... Just a little puff of rubber smoke and tire squeal... I don't want to risk tranny damage or loss of control so need to know what is the best way to satisfy my nephew's request.
Thanks,
Wkdgood
Old Sep 8, 2006 | 02:55 PM
Fritzauf's Avatar
Default Re: How to spin tires with Automatic?
Honest Officer,... My 11 year old Nephew made me do it!
Old Sep 8, 2006 | 03:27 PM
ben47's Avatar
Take him to a drag strip...
Old Sep 8, 2006 | 03:30 PM
former NXMX5's Avatar
if the ESP/TC will let you...
(1) turn traction control off.
(2) put the car in D (or "1").
(3) hold the brake.
(4) press the gas.
Old Sep 8, 2006 | 03:57 PM
dynamicS's Avatar
Disconnect the hot lead to the TC ABS system. then you can do all the silly childish maneuvers you like. But with that short wheelbase you risk spinning like a top around a corner under hard throttle. You might want to get some practice in before taking the kid along for a terror ride! You'll know he's had enough when he starts crying for mommy.
Old Sep 8, 2006 | 04:52 PM
bobs's Avatar
... or when he re-decorates your leather interior with his lunch!
Old Sep 8, 2006 | 07:08 PM
stryfox's Avatar
(3) hold the brake.
(4) press the gas.
Yup this works, i um... have done it.
If you keep the car straight you will spin both tires.
Enjoy.
Old Sep 8, 2006 | 07:16 PM
MI1XFIRE's Avatar
(3) hold the brake.
(4) press the gas.
Why isn't this car making any tire noise? it doesn't even move anymore.
Sh*t, I forgot to tell him to release the brakes...LOL.
Old Sep 8, 2006 | 08:01 PM
dynamicS's Avatar
Enjoy.
Are you sure you can spin both tires at the same time? I don't think our cars have a posi traction unit in the differential, maybe the srt does?
Old Sep 9, 2006 | 10:12 AM
ws6vert's Avatar
...how?? Be sure the auto is mounted up to the SRT-6 engine! Smoke on demand!
Old Sep 9, 2006 | 10:17 AM
Copernicus's Avatar
Originally Posted by wkdgood
Hi All,
Thanks,
Wkdgood
Try this (works everytime):
You can use soapy water for less resistance, but here's what you do.
Drive up to any brick wall, and try to push it out of the way.
Old Sep 9, 2006 | 03:47 PM
rapitrol's Avatar
Rear tires at $300+ a pop and you want smoke???
Old Sep 9, 2006 | 03:54 PM
my65cuda's Avatar
He's 11, he won't really understand the assistance of water. Just lay a little water down first. Power brake it from there, you should be good to go.
I set a personal record in my truck today. I managed to use the entire interstate ramp as a burnout strip. The truck was at 85 when I finally had to let out of it so I could regain grip and get on the interstate safely. The marks are quite impressive.
Old Sep 10, 2006 | 11:16 AM
polywave's Avatar
After reading this I tried my automatic. We FINALLY got a little rain up here in the Pacific Northwest. I just turned off the traction control, and floored it! My first attempt was while making a turn and I did do a little fishtailing, but not sideways anyways like my old charger would do. I made a second attempt at a light, straight ahead. This time the little fella went strait as an arrow. I felt that I could burn the tires for as long as I wanted (I was at about 3,000 RPMs). BTW: this was all with that switch in summer mode. Not sure if I would get the same results on dry pavement.
Old Sep 17, 2006 | 09:19 PM
stryfox's Avatar
It leaves two black marks.
Old Sep 17, 2006 | 09:42 PM
dynamicS's Avatar
It's just from the looking at the pictures of the rear diff in the repair manual, I can't see any clutches. It looks like a peg legger, maybe its a generic picture.
But it does make sense. I pulled into a 7-11 today and I managed to get one wheel in the air, due to the angle of the driveway. I could hear the right wheel spinning, but the car continued to drive up into the parking lot...
Old Sep 17, 2006 | 11:55 PM
05blacksrt6's Avatar
put one foot on the brake and then floor it, and make sure traction control is off. and then you should see alot of smoke. lol.
Old Feb 4, 2009 | 02:13 PM
welder7018's Avatar
press the brake and hammer the *****....turn the wheel a bit when leaving off the brake= fun
Old Feb 4, 2009 | 03:12 PM
apkano's Avatar
Life is random...so am I.
Much easier to just pop the 2 fuses out.
Old Feb 4, 2009 | 06:11 PM
downwardspiral's Avatar
this thread is 3 years old
