Roadster trunk question
Old Oct 16, 2006 | 07:51 PM
BRappaport's Avatar
Default Roadster trunk question
A question for you roadster owners,
I have an '05 roadster. The trunk looks normal when the partition is up so you can put down the top. If you fold the partition down and forward...for max space in the trunk...I noticed that there are motors and other components that are open to view and are not covered-up. I expected they would be covered so things you put into the trunk would not interfere with then...plus...it looks more professional.
Is that the way it's suppose to be? Can someone post some pics of the trunk with the partition folded down.
Thanks,
Ben
Old Oct 16, 2006 | 08:04 PM
2005-SoCalXfire's Avatar
Default Re: Roadster trunk question
I don't seem to have that same situation and wonder if you are missing something. Can you post a photo of what you are talking about?
Old Oct 17, 2006 | 09:29 AM
Sharonaln67's Avatar
Thanks,
Ben
I checked it out last night after I got home and put the top up and I can't see anything when that partition is down. My entire trunk is covered with the black felt stuff that the partition is covered in.
It sounds like you are missing a cover for inside your trunk.
Old Oct 17, 2006 | 12:01 PM
coony3737's Avatar
with the partition down, i can also see some hydraulic lines and the lock mechanism.
Old Oct 17, 2006 | 03:52 PM
buggy4crossfires's Avatar
Just dropped my partition for the first time since I own the car. If you bend down and look in you can see the whole shooting match. Can the partition be hung further in to cover the motors etc. or is it removable? I'm afraid to start fiddling with it as I've had no problems with the tops function and I'm not looking for any now.
Old Oct 17, 2006 | 10:48 PM
You should not try to alter the cover, as it has safekeeping switches that disable the roof from going down, if not in the proper position. When your top is up, you should be able to engage the cover to block all that wiring and mechanical components.
Old Oct 18, 2006 | 07:09 PM
BRappaport's Avatar
With the partition in the up locked position...it allows you to lower the top which would rest in the stowed position behind the partition.
With the top up...the partition can be left in the up position...giving 3.6 cu feet of trunk room up to the partition...or you can lower the partition and fold it forward where it velcro's to the back wall of the trunk. In this position...you now have 7.8 cu ft of space in the trunk...but in this stowed position...if you now look inside to the sides of the trunk...you can now see wire harnesses, and other exposed frame supports, etc that is not covered like the rest of the trunk...maybe I am missing some cover panels. Can someone verify what you have. Is this normal?
Thanks...Ben
Old Oct 18, 2006 | 07:31 PM
You're not missing anything.
Hoppy
Dec 7, 2018 07:36 AM
SuperD500
Jul 23, 2015 02:53 PM
Dave Wilson
Jul 18, 2015 05:31 PM
DKAwildcat
Jul 17, 2015 04:58 PM
tom2112
Jul 12, 2015 04:41 PM
