Shaving the emblem?
Old Feb 1, 2007 | 06:07 PM
Gwetoe's Avatar
Question Shaving the emblem?
How is the emblem and lettering shaved off of the boot of the car? I thought that they were drilled/screwed in. Or are they just applied and glued on?
Old Feb 1, 2007 | 06:11 PM
Default Re: Shaving the emblem?
They are glued on with 3M adhesive. You can use a fishing string with up and down smooth strokes to take them off. I think Andrew suggested that by applying some Goo-Gone first, they come off easier.
Just make sure you polish and wax the area after you've completed the job.
Old Feb 1, 2007 | 06:12 PM
Gwetoe's Avatar
What is "finishing string?"
Old Feb 1, 2007 | 06:14 PM
Oops, I meant fishing line.
Old Feb 1, 2007 | 06:16 PM
buggy4crossfires's Avatar
"F I S H I N G" string as in fishing line. Its stronger than most ordinary string. You can heat the area with a blow dryer too but mine popped right off with little effort and no heat.
Old Feb 1, 2007 | 06:18 PM
Gwetoe's Avatar
Cool, and thank you. I just got home and it's been a long day of work. I guess I read it wrong. I need a drink.
Old Feb 1, 2007 | 09:30 PM
Maxwell's Avatar
you can twist off the lettering with your fingers, then rub off the adhesive with mineral spirits.
Old Feb 1, 2007 | 09:31 PM
Maxwell's Avatar
what's a boot?? you must mean the trunk lid, ay?
Old Feb 1, 2007 | 09:41 PM
andrew's Avatar
-C-I-C-C-I Associate Member
~ i debadge all of my cars and this is my proven method:
wash car thoroughly around the badging (power wash)... removing any dirt beneath the letters...
heat each letter with a blow dryer to loosen adhesive... (one at a time)...
side a piece of fishing line back-n-forth beneath the letter to loosen (do NOT pull up on letters - you will chip the paint w/ the sharp edge of the letter)... allow the fishing line to loosen the letter entirely until if falls off the hatch area.
use "goo gone" on a micro fiber towel to remove remaining adhesive... rubbing your finger back-n-forth on the adhesive will also aid in its removal.
polish the paint surface with a non-abrasive polish... then wax area.
Old Feb 1, 2007 | 10:07 PM
Maxwell's Avatar
after you pop off the crossfire letters, you should pop out that Chrysler emblem and fit in a Bentley logo. lol.
Old Feb 10, 2007 | 10:24 PM
Fritzauf's Avatar
I used DENTAL FLOSS. Everyone should have some. Takes about 10 seconds to complete the job.
4drturbo
Jan 3, 2019 02:46 PM
pioneer4x4
Apr 17, 2016 10:26 AM
MissSilky
Jul 22, 2015 04:28 AM
axnguyen
Jul 21, 2015 11:41 AM
my65cuda
Jul 18, 2006 05:16 PM
