Question !!
Old Oct 1, 2007 | 11:55 AM
Default Question !!
I am buying the Stern ST1 wheels from Silver Fox. I assume the TPI tire pressure senders are independent RF units. Can they be installed in custom wheels and still do their job? If not, how would you disable them so the warning light is not constantly on? I would like to keep this feature, if possible. "help".
Thanks.
Old Oct 1, 2007 | 01:53 PM
apkano's Avatar
Life is random...so am I.
Default Re: Question !!
I would suggest that you use the sensors currently on your stock wheels.
Here is the description of the sensors from the service manual:
OPERATION
Each tire pressure sensor/transmitter serves three functions:
²
It is used as a valve stem to inflate and deflate the tire.
²
It periodically measures tire pressure. (Approximately every 30 seconds).
²
It transmits the tire pressure value to the low tire pressure warning module in the vehicle. (Approximately
every 60 seconds or if tire pressure changes by one psi or more between transmissions).
The system operates by monitoring a radio frequency transmission from the sensor/transmitters located in each
wheel. When the vehicle reaches a speed of approximately 32 km/h (20 mph), centrifugal force created by the rotating
wheels closes a roll switch inside each sensor/transmitter, powering up the circuitry.
The sensor/transmitters will only send out information when vehicle speed is above 32 km/h (20 mph). To facilitate
transmitting the radio signal to the TPM module, the valve stem acts as the antenna for the tire pressure sensor/
transmitter. When the TPM module senses that pressure is below one of two calibrated thresholds, (low pressure or
critical pressure) the TPM system will set a diagnostic trouble code and indirectly operate the "Low Tire" pressure
indicator lamp and the chime tone through the body control module (BCM).
The tire pressure sensor/transmitter is powered by an internal battery. The battery is not replaceable separately. In
the event of battery failure, the entire tire pressure sensor/transmitter at that wheel will require replacement. To
extend the life of the battery, the sensor/transmitter is not activated until the vehicle reaches a speed of approximately
32 km/h (20 mph) as stated earlier.
Each tire pressure sensor/transmitter has a unique identity code. This will allow the TPM system to indicate to a
technician, through diagnostic trouble codes in the module, which tire of the vehicle has lost air pressure. This code
is also used to identify to a technician which pressure sensor/transmitter has set a diagnostic trouble code. For this
reason, if a tire pressure sensor/transmitter needs to be replaced, the new sensor/transmitter must be programmed
to have its identity code recognized by the receiver.
Old Oct 1, 2007 | 07:48 PM
Very interesting, and a lot more complicated than I thought. Thanks for taking the time. I didn't realize they were independent and had too each be programmed. I wish I knew how to reprogram them so I could use two different sets of wheels.
Old Oct 2, 2007 | 03:42 AM
apkano's Avatar
You need a DRBIII scan tool according to the manual. I'd post the process, but I'm at work, away from the manual.
TerryR
Dec 13, 2019 03:27 PM
jimf
Oct 10, 2015 10:22 AM
2005 Ragtop
Oct 3, 2015 03:01 PM
Charlesl
Sep 30, 2015 10:46 PM
brandoni
Sep 30, 2015 07:48 PM
