Beeping sound
Old Jun 17, 2008 | 01:34 PM
SET4ORD's Avatar
Question Beeping sound
Hey, has anyone had this happen? For no apparent reason, every once and a while a beep goes off in my roadster. It is not my blinkers that are on too long either. I hear the beep and look around and there is no light blinking on the dash board. It is not the convertible top either. Any guesses? Thanks all.
Old Jun 17, 2008 | 03:29 PM
Default Re: Beeping sound
Do ya wear a hearing aid ?? lol ..........Don't have a clue but if ya figure it out let us know.
Old Jun 17, 2008 | 03:50 PM
ws6vert's Avatar
So it will beep if your blinkers are on too long?
Old Jun 17, 2008 | 03:54 PM
crossfirefun's Avatar
check the partition in the trunk, make sure it is latched good. Also check the trunk lid, mine was beeping instead of opening the other day and it was because the trunk lid was not latched completely. Isn't there a beep for the pop up spoiler if there are problems there? Seems to me there was a thread on that here.
Hope this helped.
Old Jun 18, 2008 | 06:19 AM
ws6vert's Avatar
I'll just have to try it and see.
Old Jun 18, 2008 | 08:30 AM
CrossfireLTD's Avatar
Cool Re: Beeping sound
The only "alert/warning" beeps that I know of are for the top/partition, seat belts and spoiler.
Old Jun 21, 2008 | 05:19 PM
srt6_crossfire's Avatar
Another reason for the beeping while moving is from parking brake still on or just partially on (ie. not pulled up all the way). Not saying you drove with it on but just a reason for the beep.
Old Jun 22, 2008 | 10:07 AM
Chris Newman's Avatar
Question Re: Beeping sound
I have also experienced this problem. The beeping occurs for absolutely no apparent reason. I've never been able to figure it out either.
Old Jun 22, 2008 | 11:08 AM
Goldwing's Avatar
In my roadster, I've noticed a very soft "beep" coming from the airbag indicator in the dash, usually accompanied by it lighting up. I believe this is just telling me the passenger airbag is off, which is good since no one is sitting in that seat. I have not heard it once underway.
Old Jun 25, 2008 | 10:48 AM
Aero Blue in Chicago's Avatar
I too have heard the beep. I then noticed that my Odomoter said "HI" followed by a warning like Oil Change needed or something to that effect.
Old Jun 25, 2008 | 01:02 PM
calxfire's Avatar
^^^^ HI means there is too much oil in your crankcase and you need to drain some of it. You can verify this by checking your oil dipstick. Don't drive around with an overfilled crankcase as I'm sure this will cause problems down the road.
Old Jun 27, 2008 | 05:36 PM
MCathieE's Avatar
thank god someone else has this problem. From time to time I experience the warning beep for no apparent reason. I have bionic hearing so hearing aids,I am not blonde (sorry golfergal and all the other wonderful blonde crossfire owners), I am quite familiar with all the warning systems but cannot explain this odd beep-beep. I have concluded that Lucy may have her own personal opinion about where she wants to go and sometimes voices her feelings the only way she can!
I parked at a local hotel underground garage for a breakfast meeting the other day. Saw a sparkling blue roadster parked there. Also saw an incredibly restored old Jag and a mint condition MGB. I am wondering if they all belong to the owner of the hotel - billionaire Terry Matthews. If so, he has good taste!
Cathie
Old Jun 27, 2008 | 06:31 PM
magneticred's Avatar
I experienced such a beep after letting my sister-in-law raise and lower the top. While lowering the top, she let go of the button a few times causing a brief pause. With the top closed and while driving, I heard the beep several times with no warning light. The next day the trunk would not open. I raised, then lowered the top. The trunk now opens normally, and no more beeping. Even though I thought the top was fully stowed, I suspect the car felt it wasn't fully secured. This is the only time this happened.
Old Jun 27, 2008 | 08:31 PM
OL_Coach's Avatar
Watch were you set your arm on the center console. I was driving one nice sunny day, top down wind blowing in what is left of my hair when I heard a beeping sound just barely audible over the sound of the road and music. I looked around then saw the top acting like a parachute! It must have been quite a site for the other drivers to see my top going up at highway speed. I am amazed that there is not a protection built in to prevent this from happening.
Old Jun 28, 2008 | 12:48 AM
Top shouldn't go up when it hits a certain speed. I too have depressed the button and all it does is beep when going at freeway speeds.
Old Jun 28, 2008 | 02:22 AM
OL_Coach's Avatar
Who knows? It was one of those roads with those damn red lights on them. I may have started the top up at the stop light and did not notice it until I got back to highway speed. In anycase the top should not go up when the car is in gear.
Old Jun 28, 2008 | 07:26 AM
lesr's Avatar
I am not sure about the beeps but as far as the top going up I know that I can put my top up as long as the car is only moving under say 15KM per hour. Works wonderfully for me when I am looking for a parking spot in an underground garage.
Old Jun 28, 2008 | 05:36 PM
rw138's Avatar
check your message center.. mine has beeped a few times after an oil change.. dealership put 9 qts in instead of 8.5 qts. Will show hi oil if that is the case.
Old Jun 28, 2008 | 06:24 PM
... In anycase the top should not go up when the car is in gear.
Actually, it can go up while in drive. I usually have the top in process of closing while i pull into my driveway. The actual speed limit where you can be moving and operating the top is shown in the owners manual.
Old Jun 28, 2008 | 06:28 PM
acrispy1's Avatar
Aero Blue in Chicago, join date Oct 2004 and this one gets your attention, what took you so long to post?
tcar32909
Aug 1, 2024 02:41 PM
TerryR
Dec 13, 2019 03:27 PM
Reliableron
Oct 17, 2015 10:19 PM
brandoni
Sep 30, 2015 07:48 PM
eatmycrackers
Sep 23, 2015 09:08 AM
