Roadster rattle with top up
Old Sep 20, 2008 | 04:40 PM
TEDFITZ's Avatar
Default Roadster rattle with top up
Can't locate a vibrating noise over rough surfaces - with top up. It seems to come from behind the seat at ear level. Have tied, taped our buffered everything I can find but it still is there. Took rollbar enclosures/gaskets off and tightened everything in there as well. Does anyone know if there is wire or cable going through any of the framework? Any other ideas?
Old Sep 21, 2008 | 08:56 AM
maxcichon's Avatar
Default Re: Roadster rattle with top up
I presume you've stopped the mecanism with it in the "goal-post" mode (1/2 way, both rear deck and top in UP position)? It seems there are approximately 1,000,004 possible things to rattle.
At what speed does it start? Does it come and go?
I'll take a look today and see what I can see.
Max
Old Sep 21, 2008 | 01:20 PM
CrossfireLTD's Avatar
Cool Re: Roadster rattle with top up
Try adjusting your seat away from the bulkhead, if your seat is touching the bulkhead the seat will rub or vibrate.
Old Sep 25, 2008 | 02:01 PM
TEDFITZ's Avatar
Max
any speed. a sharp bump or even certain engine rpms. I can't find anything by checking the top at any position while not moving. thanx for reply
Old Sep 25, 2008 | 02:14 PM
maxcichon's Avatar
Centered? Left or right? Is it a "buzz" or a "rattle" (high frequency or low)? Does it happen even when you're idling at a light (in gear, brakes on)?
I'll try things on my end if you can give me any clues.
Hoppy
Dec 7, 2018 07:36 AM
PimpDaddy
Sep 29, 2016 11:55 PM
UNDER PSI
Aug 1, 2015 02:11 AM
mobilefitt
Jul 28, 2015 03:45 PM
mike28117
Jul 17, 2015 01:59 PM
