Blondes, leaky trans, and cupholders...
Old Nov 1, 2008 | 01:15 PM
aftcg's Avatar
Default Blondes, leaky trans, and cupholders...
Hello everyone!
I have been perusing this site for about a month and have decided to get out of the dark corners and say hi. A fun site y'all have here!
My GF has an 05 drop top that she drives like a grandma. 56k on the miles, broken cup holder, (lasted to 55,999 miles), an new meat on the rims. I'm a chevy guy, and hardly fit in the xfire, (6'3" 230 lbs) but what a freakin sweet ride. I don't know if anyone shares this problems, but I feel I'm keeping the commitment to this hot blond to keep the privledge to pilot this cool little black thing. Oh well, it's worth it.
I did a search here looking for a solution to a tranny that likes to leak ATF when it sits for over 4 days or so. The xfire is a daily driver and has no other problems. Can some one give me a pointer to where to find a thread on the topic? I can get under the thing if I set aside some time and peek up there. And, I am handy with a garage fulla tools.
Eric
Old Nov 1, 2008 | 01:20 PM
Default Re: Blondes, leaky trans, and cupholders...
Welcome! There is a TSB out to fix the leaky trans. Take it to the dealer and have them do it for free. You might even get them to replace the broken cup holder. It was covered under warranty. The cup holder can be replaced with a storage bin if you prefer.
As far as the blonde thing goes, well, I've got the same problem.
Old Nov 2, 2008 | 01:21 PM
crossfirefun's Avatar
Welcome to the forum. The tranny thing is an o-ring problem. Would be an easy fix but these cars dont have a dipstick for the trans. You need to pick up a special tool.
Old Nov 3, 2008 | 08:29 AM
mickey5469's Avatar
I think the leaking transmission is pretty common (maybe not recall common) had this problem on my wife's roadster around 30,000 miles and dealer fixed under warranty and indicated Chrysler is furnishing a different seal plug to correct the problem( contrary to most posts this dealer is great ) even to the extent he advised me to bring in my SRT6 which has less than 8000 miles and if the newer plug is not used already he will replace it before the leak starts and likely out of warranty in 6 more months
Old Nov 3, 2008 | 10:43 AM
70GT6's Avatar
Originally Posted by mickey5469
I...Chrysler is furnishing a different seal plug
Yeap, I got mine fixed today.
Dealer explained that the TSB fix used to call for installing new seals now they are finding that the problem can return.
Now when repairing the leak the "kit" includes new seals and a new style plug.
*edit - for those wanting to know the plug adapter part number is 68021352AA
Old Nov 3, 2008 | 11:25 AM
aftcg's Avatar
Thanks for the info guys...Where does one pick up this "special" tool? P/N?
Old Nov 3, 2008 | 12:11 PM
tighed1's Avatar
My SRT also had the TSB service performed. No leaks since!
Old Nov 3, 2008 | 12:27 PM
70GT6's Avatar
Well unless you want to spend a bit of $...
The "tool" is about $60-$80 (it is a dip stick with different measurements on it)
Miller tool 8863B (about the cheapest I have found)
Next you need a scannner to get the exact temperature of the fluid so you can determine where the fluid level should be located on the dipstick.
(most cheap scanners do not give trans fluid temp)
Abaton6
Oct 26, 2016 10:43 AM
MK2005
Nov 12, 2015 11:11 AM
jimf
19
Oct 19, 2015 04:05 PM
rfourt
Sep 25, 2015 01:38 PM
josh armstrong
Sep 22, 2015 01:19 PM
