New roadster antenna
Hey, if I didn't give you a hard time, I wouldn't love 'ya!
Originally Posted by roncosrt6
FP, do you know if the antenna you are using picks up the IPOD FM transmitter any better than the stock??
I have the 16V TVT antenna (the same one that FP has) and am using the medium-length middle section...I have not noticed any difference from the OEM antenna when using my FM transmitter. I'm using the low band (88.3 Mhz) - haven't tried the high band because we have a strong radio station here right around that frequency.
I tried the longer one but my reception was always terrible. AM was unusable because of static and lousy reception with both the OEM and the replacement. There is a TSB about the mount, but it didn't do too much when the dealer fixed it. So, I installed one of these on the windshield. It isn't too noticeable and the reception is unbelievable.
http://www.midwestelectronics.com/bl...nna-p-507.html
I swapped the one from my '07 Lincoln MKX which is going back from lease in a couple weeks. It is about 10" long and fits perfectly. Reception seems as good if not slightly better and my iphone 3g/Griffen transmitter works fine. I think the Roadster looks much better with the shorter antenna.
