Another stupid question from Learnin
Old May 10, 2010 | 03:22 PM
Learnin's Avatar
Default Another stupid question from Learnin
First time I've owned an automatic with manual select option. Question. When manually shifting, does one back off the pedal like in a regular manual transmission?
Old May 10, 2010 | 03:26 PM
mjgroves's Avatar
Default Re: Another stupid question from Learnin
Nope, you don't need to let off the pedal at all. It's basically just like an automatic, but you can manually choose the shift points.
Old May 10, 2010 | 03:46 PM
Learnin's Avatar
Now you're talkin....thanks....
Old May 10, 2010 | 05:03 PM
Goldwing's Avatar
It has a little brain that does the shifting for you...but now you can tell it when to shift. So just leave the pedal on the floor and go. It will upshift or (not) downshift when it needs to, to protect itself.
Old May 10, 2010 | 06:13 PM
itsky's Avatar
Just as the others have said, no need to back off the gas. I will say that the autostick on this car is the best that I have driven. I constantly use it while driving in town. I dare say it is almost as good as a manual, but not quite.
Old May 10, 2010 | 11:56 PM
Learnin's Avatar
Thanks to all. Now I can enjoy the shifter without worrying. I am very glad to have found this forum. It has been of tremendous benefit to this rookie. Already, I have changed my own air filter, cabin filter and replaced a brake light because of advice I have received on this forum. I'm sure I've saved a bundle by doing all of this on my own....thanks again.
Old May 11, 2010 | 05:13 AM
Chris L.'s Avatar
The 6 speed manual works best when you don't let off the gas between shifts also!!
Old May 13, 2010 | 09:07 PM
NeverEnough's Avatar
If you are coordinated enough you can actually rev match down shifts like a manual transmission. I've mastered it, but it took a while. I guess the engine will free rev for a split second as the torgue converter unlocks.
Old May 13, 2010 | 10:31 PM
blackcrossfire07's Avatar
Not to change the subject... but most automatic cars now have the auto shifter. They say in the future people will be less likely to know how to handle a clutch pedal. Kind of makes you wonder.
Old May 13, 2010 | 11:19 PM
IMO, if you can't drive a stick, you never truly learned to drive... I know I have an automatic, but it isn't by choice. The SRT is the first car in many years I've owned with an automatic...
An automatic is kinda like the doggy paddle... It's kinda like swiming, but not quite.
P
R
N
Dumb
Oh well, at least the Crossfire has a really good autostick. The SRT more than makes up for it's lack of a third pedal in many ways.
TerryR
Dec 13, 2019 03:27 PM
jimf
Oct 10, 2015 10:22 AM
2005 Ragtop
Oct 3, 2015 03:01 PM
Charlesl
Sep 30, 2015 10:46 PM
brandoni
Sep 30, 2015 07:48 PM
