Bogging engine.
Old Jun 20, 2010 | 12:35 PM
Teck-9's Avatar
Default Bogging engine.
What causes an engine to bog down and stall when accelerating?
Old Jun 20, 2010 | 01:50 PM
Default Re: Bogging engine.
Check you manual. It sound like "LIMP MODE".
Old Jun 20, 2010 | 06:10 PM
You forgot to take the handbrake off?
More info needed please. You know when it happens, we do not.
Old Jun 21, 2010 | 12:28 PM
TopGear's Avatar
Has this just started to happen lately? how long have you had the car? Any tune ups in its history? Does it happen on hot days cold days rainy day? is it immediate or do you have to drive for a while before it happens? Are you using premium fuel? any other fuel additives? When you accellerate does it bog down and stay down or does it recover after a second or so?
Old Jun 21, 2010 | 12:36 PM
Goldwing's Avatar
Do you have an automatic transmission in "winter" mode? Otherwise the above questions need answering.
Old Jun 26, 2010 | 05:01 PM
plongson's Avatar
Could also be the auxiliary intercooler water pump. It's located inside/behind the front RH fender liner directly in front of the tire. They are known to STB frequently and power will drop DRAMATICALLY.
Old Jun 26, 2010 | 06:34 PM
SRT or NA?
Old Jun 27, 2010 | 09:00 AM
plongson's Avatar
Not sure what an "NA" is but I believe the only CF with a supercharger is the SRT, and you only have a intercooler pump on a supercharger.
Old Jun 27, 2010 | 09:41 AM
Cody M's Avatar
NA is "Naturally Aspirated" meaning that it has no turbo or supercharger. Basically referring to the coupe and roadster models
Old Jun 27, 2010 | 09:57 AM
plongson's Avatar
OK...I didn't pick up on the NA "Naturally Aspirated" acronym, too early on an Sunday morning...sorry.
But ya, there is no intercooler, and thus no auxiliary intercooler water pump, on an NA motor and your "bogging" is somewhere else.
Old Jun 27, 2010 | 12:08 PM
Cody M's Avatar
wasn't trying to be mean about it at all. just trying to explain it to you. lots of people don't know what it means
Old Jun 28, 2010 | 12:37 PM
Learnin's Avatar
My automatic hesitates about a second after switching gears...I think this is just a normal quirk...
Old Aug 16, 2010 | 03:58 PM
dmac's Avatar
its a drive by wire thing,you need a sprint booster
Old Aug 27, 2010 | 10:18 AM
2006 Roadster in TN's Avatar
I recently had ours in the shop for one last "under warranty" check as we'd been experiencing some sluggish performance. Occasionally when you'd pull up to a stop light it would feel like it was trying to stall and would hesitate badly when you tried to take off again.
They ended up replacing 3 or 4 plug wires and all is well now.
Old Aug 27, 2010 | 10:51 AM
Pacemaker's Avatar
Could we use a directory of common terms and abbreviations used in this forum that may be unknown to non-motorheads, or other DYIers? Sometimes it seems like the military or other Gov't. bureau around here.
If such a directory already exists here, I am unaware of it. Please direct me there. Otherwise, I'm the "squeaking wheel", so I will volunteer to make said directory if you folks will help by contributing your favorite abbreviations, phrases, jargon etc. with a clear translation and/or explanation. I'll start a thread to receive such if you want to contribute. Communication is the hardest task in human relations (see below)
Old Aug 27, 2010 | 01:48 PM
muskrat's Avatar
Did you ever sort the original problem? Mine seems to misfire occasionally just for a second as if the whole engine has cut out but goes again straight away. NA 2004 manual Roadster to avoid confusion
Ralph289
Sep 12, 2021 11:15 AM
ardenian
19
Nov 21, 2015 12:00 PM
Snake Eyes
Sep 28, 2015 08:55 PM
RiderJC
Sep 7, 2015 11:19 PM
jonq67
Aug 24, 2015 09:53 AM
