Temp down - so do roadster posts
Old Dec 16, 2010 | 11:18 AM
itsky's Avatar
Default Re: Temp down - so do roadster posts
Originally Posted by Bladecutter
We haven't gotten up here as of yet, North of Denver.
Yet, anyway.
BC.
It was a fizzle here on this side of town as well. We got about 1/2" in the grassy areas. Looks like it will be back in the 50s on Sunday and Monday.
Old Dec 16, 2010 | 11:56 AM
TiredRetired's Avatar
Originally Posted by Goldwing
No question us colonials are spoiled by cheap petrol -- now peaking at about $3/gallon. It would not bother me one bit to see $1/gallon tax if it would reduce the number of speeding Hummers and Prius' and they used the funds to start rebuilding our crumbling superhighways. And I'm used to driving 30-40k miles per year between my two Crossies and an A6. I've driven quite a bit on the continent (and Ireland) and the distances are noticeably shorter in EMEA than they are here in the states. Crossing Germany is like going across Michigan and Illinois, just a lot more fun.
I very respectfully disagree that more taxes are the answer. I do not believe that we have cheap gas, the euros have expensive gas. They tax their people to death and have been for centuries. Spend wisely.
Old Dec 17, 2010 | 02:05 AM
ShaunXFire's Avatar
Originally Posted by OKC-XFR
If your mileage is that low at that speed, something is wrong. I get 31+ mpg driving at 65-70 mph; 29+ driving 75-85 mph. I typically get 23-25 mpg driving mixed city/highway during the week to and from work.
My mileage was dropping for a while until I changed out my spark plugs (NGK Iridium) and wires (Magnecor) - as soon as I changed them, the mileage/performance jumped back up. I inspected the old plugs and wires and couldn't see anything wrong, but it sure made a difference.
What RPM's is your engine at when you are at 65? It should be between 2000 - 2500 RPM - maybe you're not shifting into overdrive?
Looks to me like its time for a tune up!!!
I get horrible gas mileage but then again my previous car got 32 MPG
My car is an automatic so no overdrive for me?
I dont think.. Is there an O/D button?
Old Dec 17, 2010 | 10:20 AM
OKC-XFR's Avatar
I'm not sure - I drive a stick...maybe an automatic driver can chime in? You should be able to tell by the engine RPM's at 65 mph, though.
Didn't I see one of your posts that said you were smelling gas fumes? Maybe that is your problem - you could be leaking gas and that is killing your mileage...although you would have to be leaking ALOT of gas (several gallons worth) to drop you mileage that much.
Old Dec 17, 2010 | 10:29 AM
itsky's Avatar
5th gear (or D) is OD on an automatic and is pretty much the same as 6th gear on the manual.
Old Dec 18, 2010 | 01:56 AM
ShaunXFire's Avatar
At 65 mph my RPMs are at 2400.
Is that normal?
Old Dec 18, 2010 | 12:38 PM
itsky's Avatar
Is that normal?
That sounds about right. Shaun, have you changed out the air filters? Checked to make sure that your air intakes are clear and that the engine cover is securely mounted? I had a Jeep Wrangler once were a mouse got into some birdseed and decided to store it in the compartment where the air filter goes. Half of the compartment was filled with birdseed! Any check engine lights?
Old Dec 18, 2010 | 01:53 PM
I get 28-32....when my foot stays out of it....which isn't often...never below 22 though....
Old Dec 18, 2010 | 02:26 PM
markr6754's Avatar
My baby stays in the garage for the winter, and the Dakota 4x4 becomes my regular driver. Don't mind cold (except my seat heaters quit), but I am on a low sodium diet....and what's good for me is good for my Roadster.
I'm envious of the 28-32 MPG drivers here. Best I've ever had was 27, staying in the legal speed limit. Normal driving I average about 22, with the rare 25+ showing up. I don't mind getting 22, which is much better than the 14-15 my Dakota gets. When the snow and salt or gone I'm quickly back into the Roadster.
Old Dec 19, 2010 | 04:08 AM
ShaunXFire's Avatar
No check engine lights at all, im going to clean all filters out and do an inspection of the engine first thing tomorrow.
Old Dec 19, 2010 | 05:31 AM
yanni2112's Avatar
If you drive at more "legal" speeds, the gas mileage is even better. Michigan is 70 and if I stay close to that it gets 28-29. At a steady 100 kph, you can achieve 30+. But I don't have that much self control even when I am driving through Ontario!
The only time I hit 80 mph is when I'm slowin' down!
KDW4Him
18
Sep 1, 2021 05:47 PM
stlas69
Sep 3, 2015 10:28 AM
RED DOG
Jul 22, 2015 08:55 AM
waldig
Jul 15, 2015 02:05 PM
Mackel
Jul 6, 2015 10:54 PM
