windows when doors opened Roadster
Old Jun 21, 2011 | 05:04 PM
white05conv's Avatar
Default windows when doors opened Roadster
I was wondering if the windows are supposed to go down alittle when the doors are opened (i saw this happen on an 05 pt cruiser conv and also a
bug conv) If it was on an 05 pt then I would think it should have been on an
05 roadster limited.
Old Jun 21, 2011 | 06:17 PM
magredvet's Avatar
Default Re: windows when doors opened Roadster
Nope doesn't happen, there are absolutely no similarities between a PT cruiser and a Crossfire, other than the badges. If it happens on an 04 SLK32, then I would expect it on a Crossfire
Old Jun 22, 2011 | 07:28 AM
The windows do go down when you unlatch the top though.
Old Jun 24, 2011 | 12:54 PM
xfchris's Avatar
dont have a xf roadster but used to have a pt cruiser vert and the windows drop as you open the doors because the window tucks up under the roof..was a right pain in the a*** when it was frosty and the window was frozen to the roof..and wouldnt drop so couldnt open the door.
Old Jun 24, 2011 | 02:27 PM
I noticed the window drops about an inch on the new Challenger coupes as well. Gives you a tighter seal after the door closes and the window actually tucks up under a flap.
Old Jun 24, 2011 | 02:38 PM
Our 06 VW New Beetle ragtop has this feature, most likely for the same reason as other ragtops mentioned above. I had to replace the DS power window motor shortly after we bought it in 2010. And most VW New Beetle ragtops have this occur after years of ownership. Repeated up & down movement must take its toll on the motor.
Old Jun 24, 2011 | 03:52 PM
noles's Avatar
It would be a nice feature but unfortunately our car doesn't do this. That feature is to make sure you get a good seal between the glass and the top. It also protects the window as well. BMW convertibles also do that.
Old Jun 24, 2011 | 04:10 PM
Thirteendog's Avatar
I remember watching a Chrysler Dealer Video of the Roadster doing this when you open the door. My SLK's windows do it.
Old Mar 27, 2021 | 02:54 PM
cobra66's Avatar
I just bought an 05 Crossfire convertible and the windows don't drop when opening and closing the doors. The problem I see is the window has a large gap/opening at the back of the window that would let water in. If I have the wife roll down the window and back up with the door closed, NO GAP.
Old Mar 27, 2021 | 06:47 PM
If running the window down and back up temporarily fixes it, I'd say that it sounds like a worn/sloppy "Window Regulator".
RED DOG
May 4, 2019 08:05 AM
spoiler
Sep 2, 2015 08:56 PM
xzmilan
Jul 22, 2015 10:40 AM
waldig
Jul 15, 2015 02:05 PM
