Sterns, Spacers & Lugs Specs.
Old Jul 25, 2011 | 06:45 PM
rtman's Avatar
Default Sterns, Spacers & Lugs Specs.
Finally got the wheels on with no high speed vibration. Here is what I did if anyone else is interested or in the same dilema. Im no longer going to sell my Crossfire!
Front Wheels
18X8.5
35mm offset
5X112 bolt pattern
10mm thick hub centric spacer with centering ring (for dust cap to fit)
63.25mm - increased bore size on centering ring performed by a machinist
39mm shank length - Conical lugs 12mmX1.5
Rear Wheels
19X9.5
35mm offset
5X112 bolt pattern
15mm thick hub centric spacers with centering ring
39mm shank length - Conical lug 12mmX1.5 (1mm to long could possibly damage E-brake)
Old Jul 25, 2011 | 10:02 PM
tom2112's Avatar
She can ride with me ;)
Default Re: Sterns, Spacers & Lugs Specs.
Am I missing something? How did you get rid of the vibration? Replacing wheels and tires?
Old Jul 25, 2011 | 10:08 PM
jmk41's Avatar
The vibration had to have been caused by an issue with the centric spacers.
Old Jul 26, 2011 | 07:46 PM
tom2112's Avatar
Ah! Now I get it.
By the way, I had Eurocharged attempt the tune last Friday. They couldn't do it. They said the cable was bad. So they're sending me another cable. I don't have it yet. But I'm pretty darn sure the cable is fine. But I'll keep ya posted.
Old Jul 26, 2011 | 09:25 PM
jmk41's Avatar
sorry tom to my knowledge the cable is fine i only used it once... your a tech-ish guy as long as the pins aren't bent there isn't anything wrong with it...
Old Jul 27, 2011 | 04:10 PM
tom2112's Avatar
I'm sure the cable is good. My ECU is a little different than most, I think. I remember when they first tuned it they had trouble. Apparently, they didn't leave themselves a note for next time, LOL.
tom2112
Dec 1, 2015 09:02 AM
gblack32
Sep 30, 2015 01:13 AM
grip grip
31
Sep 27, 2015 10:06 PM
Sep 26, 2015 10:21 PM
04Fire
Sep 15, 2015 07:40 PM
