having problems with my convertible top retraction process.
Old Dec 24, 2011 | 04:03 PM
smiley4505's Avatar
Default having problems with my convertible top retraction process.
so i have a 2005 crossfire roadster and recently when i put the top down the left wing that is supposed to flip up and snap into place on the body is staying down and i have to manually lift it up and then the back piece will come down and click into place. when i put the top back up it goes back down into place and works fine its just when i put it down i run into the problem. anything will help! thanks!
Old Dec 24, 2011 | 04:14 PM
Hangman's Avatar
Default Re: having problems with my convertable top retraction process.
I beleive those flaps are spring loaded to go out and pulled in when the top is up. check the springs on it to make sure nothing is caught or maybe a little lubricant might help.
Old Dec 24, 2011 | 04:26 PM
smiley4505's Avatar
thanks i will try lubricant it looks like its a small cable that pushes the flap up and then the wire pulls back in to bring it back down. its just the pushing out the wire isnt doing for some reason.
Old Dec 24, 2011 | 06:31 PM
hcarter's Avatar
The flaps operate by cable I had one of mine break before and had to have it replaced . check and make sure it just hasn't slipped . with the boot up in the air look at the cable on the side that wont go down... good luck
Hoppy
Dec 7, 2018 07:36 AM
PimpDaddy
Sep 29, 2016 11:55 PM
rec3rd
Jul 31, 2015 06:13 AM
2004_
Jul 29, 2015 05:17 PM
mike28117
Jul 17, 2015 01:59 PM
