Towing a Trailer
Old Jul 6, 2004 | 08:55 PM
al_luss's Avatar
Default Towing a Trailer
Hi guys
Since the roadster is limited in the trunk area is there any way to put on a light weight hitch on the car to tow a small motorcycle like trailer?
Thanks
Old Jul 6, 2004 | 10:33 PM
Doc's Avatar
Doc
Default
Where theirs a will there is always a way. For example take a look at this:
http://www.inficad.com/~moneymanager...tewtrailer.htm
I may consider the same option as well someday.
Doc in Mesa
Old Jul 7, 2004 | 12:01 AM
David Burns's Avatar
Default Re: Towing a Trailer
Originally Posted by al_luss
Hi guys
Thanks
Try the search function here. There have been a couple threads about towing with the Crossfire (so far no proof of anyone doing so). Actually, it's more about the miniscule load capacity of the Crossfire than can a hitch/trailer be done. Of course it can be, but the car is NOT setup for towing and I'd suspect if you developed any drivetrain troubles and D/C found out you'd been towing, you'd run the risk of warranty being voided.
Old Jul 7, 2004 | 01:54 AM
Doc's Avatar
Doc
Default
If the Crossfire couldn't pull a light trailer enough for some decent luggage then it's not much of a car.
Which I don't think is the case.
Just my opinion.
Doc
Old Jul 7, 2004 | 04:02 PM
Bill Welch's Avatar
Default
I thought it was clever how they fitted the Prowler with as prowler look-a-like trailer. If they can fit a Prowler...well
Old Jul 7, 2004 | 04:05 PM
Doc's Avatar
Doc
Default
I totally agree!
The shape of the Crossfire would sure make for a nice looking and streamline trailer. Let's get one and cut off the nose to use for a trailer oK? HA
Doc
Old Jul 7, 2004 | 04:52 PM
bornfeld1's Avatar
Default Your VIN #
Hey Doc,
Your VIN # should show the last 5 digits. My roadster # is 25616
Old Jul 7, 2004 | 05:24 PM
Doc's Avatar
Doc
Default
Thanks I didn't know which numbers to use. I made the correction.
Thanks
Doc
xfireohio
Jul 20, 2020 12:03 AM
franklindm
Mar 14, 2020 12:23 PM
Vegaslegal
Sep 10, 2015 11:24 AM
hhr hellshotrod
Aug 17, 2015 11:27 PM
gtjl
17
Jul 22, 2015 06:28 PM
