Turning a Limited into a SRT-6
Old Apr 15, 2012 | 07:07 PM
Jennasdad's Avatar
Talking Turning a Limited into a SRT-6
Hi, new to the forum. Finally convinced the wife that I need a Crossfire. I want a SRT-6 but also want a convertible and a stick. Can a limited be upgraded to a SRT and what would it cost?
Old Apr 15, 2012 | 07:19 PM
SparkieSRT6's Avatar
SSB SRT6 405hp/401Tq
Default Re: Turning a Limited into a SRT-6
Been discussed here.....over and over.....and over. I used the search tool and found a thread here :https://www.crossfireforum.org/forum...ase-xfire.html
Old Apr 15, 2012 | 07:36 PM
05roadsterguy's Avatar
Wink Re: Turning a Limited into a SRT-6
Indeed Sir I can think of at least 4 or 5 actual threads that discuss the subject. There are probably 10-15 in the tech sections that deal with the idea. Lots of good reading.
Old Apr 15, 2012 | 07:41 PM
In short, you can buy a SRT6 Roadster, but you had best learn to live with the 5 speed automatic ....
The other option is to buy a 6 speed limited roadster and sign up on the BEGI list for the turbocharger. ( thats a sticky thread you can search for )
( there seems to be a bit of debate about if the 6 speed clutch can handle the extra HP/Torque however )
Old Apr 15, 2012 | 07:56 PM
if you go to make changes like that, why not just go to the V8, jim
https://www.crossfireforum.org/forum...ht=building+V8
Old Apr 15, 2012 | 08:17 PM
The Beep's Avatar
You can do anything but the short answer is... it would cost a fortune.
Old Apr 15, 2012 | 08:22 PM
Use the search function and start reading, the answer is not simple.
And it is one thing to convince her that you need a Crossfire, how ya gonna justify buying an N/A roadster for at least $12,000 THEN spending $6,000 to $20,000 to create a six speed SRT-6?
Many have put various V8s in their cars and I'd go that route, myself.
Old Apr 15, 2012 | 09:02 PM
try this maybe he still has the motor and tranny. jim
https://www.crossfireforum.org/forum...es-engine.html
Old Apr 15, 2012 | 09:29 PM
The Beep's Avatar
Does the OP actually want a 6-speed SRT? He can't because SRT's are auto's. The statement is oxymoronic. Perhaps he wants a modified NA Crossfire with the HP of an SRT???
I would advise following the turbo mod threads. It's still going to cost a fortune not only for the mod but also replacing expensive parts broken by the mod not to mention sub-standard braking, suspension and aerodynamics.
He'ld be far better off screwing the 6 spd idea and just buying an SRT. .02
Old Apr 16, 2012 | 08:49 AM
You can buy an SRT6 roadster for a lot less than a conversion. I assume there was a reason Chrysler did not make an SRT6 with a stick shift?
Old Apr 26, 2012 | 03:18 PM
magredvet's Avatar
Basically because every AMG car made at the time was auto, so since the running gear is basically AMG...no manual trans
Old Apr 26, 2012 | 03:25 PM
And they did not have a manual trans that would hold the power of the SRT....
Supperman
Jul 24, 2015 09:07 PM
Romio
Jul 24, 2015 07:04 AM
UNDER PSI
Jul 18, 2015 02:12 PM
leaddog2015
Jul 13, 2015 12:25 PM
tom2112
Jul 12, 2015 04:41 PM
