"Rebuilding the convertible top hydraulic system"
Re: "Rebuilding the convertible top hydraulic system"
I know nothing about the roadster roof and it’s problems but are the DTCs readable? I see there are some 70 to 80 fault codes readable using the DRBIII tool. Can these be read using regular fault readers we use? They are in the 9000 series of codes.
P
P
on
I am in the process of rebuilding my convertible top hydraulic system on my '05 Crossfire. I received the cylinders and pump back from Klaus in an unbelievable short time. I am now putting the cylinders in the roof. My problem is I accidently hit a small micro switch on the metal frame on the passenger side as I replaced the first piece of weather stripping. I did not see it but was lucky enough to catch a small spring as it fell but lost the plastic cover and whatever else was there. The switch in not on the driver's side so I cannot determine what I need to fix it.
What is it for?
What do I need to fix it?
Where in the manual can I find the switch?
Should I continue to finish the project and go back and fix it later when I have determined what the effect is of the switch?
Where do I find what I need to fix it?
Al
What is it for?
Al
This is the "top opened" switch, it is in series with the divider panel switch in the trunk. It is a safety switch to ensure that you don't run the pump with the top still latched to the header.
As long as you don't get stupid, you can bypass this switches function by just wiring the 2 leads together.
I can almost guarantee you that you will not find a replacement part. ( been there, failed that )
I did think of a friend that I knew had bought a spare top frame from a junk yard and he sent me the switch no charge, sometimes you just get lucky
on
Update on my top issue. My Crossfire mechanic ran a full diagnostic and discovered the PTCM is fried. I have no idea how that happened, but probably something I did!
Anyway, these modules are no longer stocked/manufactured by Chrysler. I found one on eBay, took the car back to my mechanic.
He had found number 7 fuse blown and had to clear the fault codes, but got the top working again. $ well worth it.
One lesson learned: always snap pics with your phone before taking things apart.
on
Does anyone have a part number for the "top open" switch located in the top on the passenger side? I could get lucky on ebay. From the picture I see how it will work so I will continue in my search for the pieces. If not I will by-pass the switch.
The part number for the switch is a Mercedes number: A193 820 21 10
Looks like it is discontinued, however there are a few companies that make old Mercedes parts, so you might get lucky if you are patient. I was able to get a small connector shell from ECS Tuning, a Mercedes performance shop.
I have searched on Mercedes numbers like these before and the searches seem to work better if you leave off the "A" and take out the spaces.
Also, check with Chrysler using the Mercedes number and see if they can cross reference to the MOPAR version.
Try searching the national used auto parts database (can't remember the name). You may need to buy the top frame to get the switch.
I have had some luck with eBay.
Good luck!
Good luck!
on
It looks like A 193 820 21 10 Hope this helps.
on
This is all that is left. The switch mounted on the metal and the plastic frame. If the switch is in the position shown and I can push it in, does that mean I still have to short the wires to still use the up/down on the top?
Thanks for the great photos, Ray48317. I'm having trouble with that top switch myself. After unlatching the top and pushing it up a little, I have to reach over and move that spring on the top switch to get it to release and allow me to lower the top. Once the switch closes, the top goes down and then will go back up just fine. But then, I have to do it again the next time that I lower the top.
I'm reluctant to bypass the safety top switch by splicing the wires together. But, I might do that. But before I do that, I'm going to examine that spring mechanism again and see if I can get it to move more freely on its own.
I'm also wondering if the top switch could be replaced with a tilt-switch that is mounted at just the correct angle so that the switch is open when the top is latched and then as soon as you unlatch the top and push it up, the tilt-switch closes the contacts and allows the top to go down. The only trick would be making sure that the little roller ball in the tilt-switch keeps the contacts closed all the way down to the stowed position. I'll have to look at how flat the top is stowed in the down position to see if it might work. But for a $5 tilt-switch, it might be another solution to try.
on
What I need to know is
What is the condition of the switch lever when the top is latched to the front window?
When the lever is away from the switch is the switch wires set to be is the "normally open" position or "normally closed" position?
Where can I locate a schematic in the manual?
From ala_xfire #125 in this thread, you need a short circuit to complete the interlocks so you can open/close the top. I like you would prefer to have a switch there.
No company in the industrial world would have this switch designed and built for a car. They would find a suitable switch and have a wire attached to it and have their part number moulded into the sides of the body.
look for an off the shelf switch that is identical to this one.
The numbers under the Mercedes part number are the type of plastic the case is made from, it is glass filled nylon 66.
This part will be sitting in a manufacturers catalogue somewhere, find it and be a hero.
Often the makers name and part number appear on the part as well, but I cannot see it in the photo.
These types of part come off the shelf in normally open and normally closed, sometimes the wires are selected for the NO or NC requirement.
