multi function switch
Old May 28, 2014 | 03:52 PM
David C. Arnold's Avatar
Default multi function switch
We have purchased a 2008 Limited Roadster. The right turn signal work intermittently.
Replaced fuse, flasher is common to left and right, right front and rear bulbs are good.
suggestions?
Old May 28, 2014 | 03:55 PM
Default Re: multi function switch
try swapping the bulb holders from left to right.
these are notorious for intermittent connections.
Old May 28, 2014 | 03:56 PM
"The right turn signal work intermittently". That does not tell us enough.
Does it not blink? Does it blink fast? Does it not light up at all? Does it light but not blink at all?
Our answers depend on yours.
Old May 28, 2014 | 07:33 PM
suggestions?
Test for power at the contacts when they are not working if possible.
Make sure the contact is not burnt and just lightly touching the bulb.
Bend the contact so that it hits the bulb harder, clean the contact as well.
Old May 29, 2014 | 09:01 AM
rayth's Avatar
My front right turn signal didn't work for about 8 months and I finally just fixed it by bending the electrical/contact tabs up so they had better contact (the tabs in the headlight, not the bulb holder)
Osusannah
Feb 12, 2024 01:49 PM
fastfred
Nov 5, 2018 09:47 AM
Reliableron
Oct 17, 2015 10:19 PM
o55ie18
Oct 5, 2015 05:50 PM
smokey847
Sep 15, 2015 10:47 AM
