headlight adjusting
Old Dec 20, 2014 | 10:13 PM
francist44's Avatar
Question headlight adjusting
Can someone please provide the procedure for adjusting the headlights on my 2006 roadster; the low beams are near useless.
Thanks
Old Dec 21, 2014 | 11:11 AM
ChrisA's Avatar
Default Re: headlight adjusting
Just read this one today. https://www.crossfireforum.org/forum...eadlights.html
Old Dec 22, 2014 | 01:16 PM
francist44's Avatar
Originally Posted by ChrisA
Thanks for the reply, Chris.
The thread did not show/say where exactly the vertical low-beams adjustments were? Whereas the wife loves the car, I'm going to buy a set of OEM service manuals and do a write-up with photos on how-to.
Old Dec 22, 2014 | 01:38 PM
Most often the solution is to put the bulbs in correctly. In order for the bulbs to be situated in the position that gives the best and legally correct lighting, the bulb has to fit into a closely fitting pocket. If the pocket was to large then the bulbs would not be aimed correctly many times.
The tab on the bulb faces down on the low beams and up on the high beams. With the spring retainer in place the bulb can often be turned so it snaps into the correct position. Do not remove the spring, that opens another can of worms.
Adjusting the units using the white capped screws is not recommended if the bulbs are not set into the correct position. Often the bulb is correctly put in but moves out of position while the spring is being latched, ask me how I know.
Old Dec 23, 2014 | 10:28 AM
Be sure to use the link at the bottom of onehundred80,s response. It will save you buying manuals and provide valuable info.
smfrycruzr
Jul 17, 2023 05:33 PM
Franc Rauscher
May 9, 2016 12:04 PM
2005 Ragtop
Oct 3, 2015 03:01 PM
atdavis2
Sep 21, 2015 01:25 PM
RacerXofFL
Sep 15, 2015 05:00 PM
