Body Control Module and Wiper problems
Old May 31, 2015 | 10:35 AM
bourbonton's Avatar
Default Body Control Module and Wiper problems
Hello
Roadster 2005
If I fit a replacement Body Control Module does it have to be re programmed to my specific car.
My wipers will only stop when ignition is off, any ideas
Many thanks
Old May 31, 2015 | 11:36 AM
Default Re: Body Control Module and Wiper problems
I am not sure about the BCM to be programmed for your car.
Have you checked to be sure the multi-function switch is not causing the problem?
Check page 8R17 in the repair manual for diagnoses.
James
Old May 31, 2015 | 11:58 AM
bourbonton's Avatar
Thanks for reply.
I just downloaded the manual for USA,
I will check all this out andfamiliarise myself with the equipment.
Only had the thing a couple of days, Doesn't bode well.
Old May 31, 2015 | 12:33 PM
Mrmiata's Avatar
Originally Posted by bourbonton
Hello
Roadster 2005
Many thanks
My 2 cents may not be worth that..
I had swapped BCM with my wife's car into my coupe ( checking lighting in hers). When I turned the ignition on in my coupe the wipers started up - non stop - till ignition was turned off. Seems I didn't fully get the wire harness seated.
As far as programming.. I was told "lucky" I didn't try to start the car.. (programming thing)
AND
I've read somewhere along the way that approximately 20 seconds of ignition on is required for this.
Not much help but do dig into the BCM programming as best as you can.
Old May 31, 2015 | 09:57 PM
KDW4Him's Avatar
Hello
Roadster 2005
Many thanks
Did you try anything listed in this post.......
https://www.crossfireforum.org/forum...on-t-stop.html
KDW4Him
18
Sep 1, 2021 05:47 PM
rperry52@live.com
Feb 14, 2019 12:18 PM
northwest_crossfire
May 30, 2016 05:19 PM
BrenLW
Aug 5, 2015 04:53 AM
bdh
Jul 9, 2015 09:40 AM
