Jack & Accessories
Old Jun 15, 2015 | 04:44 PM
Geechee1962's Avatar
Default Jack & Accessories
Finally got around to checking the trunk for the jack. Here is a pic of what I found. The jack, a lug wrench and Chrysler inflation canister. Also the wrench for manually lowering the top. Should there be anything else?
Old Jun 15, 2015 | 05:08 PM
bluecoupe's Avatar
Default Re: Jack & Accessories
That looks complete provided the inflation pump is there also, quite often the multi-tool (wrench) is missing.
Old Jun 15, 2015 | 05:25 PM
Mackel's Avatar
It appears from the pic that the 12 volt inflation pump is missing from the opening just left of the jack
and below the fix-a-flat goop bottle.
Old Jun 16, 2015 | 11:47 PM
kjwinston's Avatar
Could someone take a picture to show what it should look like?
Old Jun 17, 2015 | 10:35 AM
Here is what I found in my trunk. All but the sliver wrench was included. I purchased it when I did not find one in the Glove Box as the manual had said it would be. The original question was the result of there being an approximately 5 x 3.5" cutout in the holder with nothing in it. Just wondered if there could be something missing. All my stuff appears to have never been used as the top wrench and inflation cylinder are still sealed in plastic.
Old Jun 17, 2015 | 10:48 AM
Southernscrew's Avatar
You are missing the inflation pump that you plug into your cigarette lighter to pump up the tire with when you put the goop in it.
Ken
Old Jun 17, 2015 | 11:40 AM
Exclamation Re: Jack & Accessories
Thanks, hope someone will post a photo of the OEM pump.
Old Jun 17, 2015 | 12:25 PM
Travish's Avatar
Here it is. But... I saw a website recently that had brand new ones about $35~$40 but I cant remember where.
http://www.ebay.com/itm/MERCEDES-SLK300-SLK350-SLK55-R171-SPAR3E-WHEEL-AIR-COMPRESSOR-ASSEMBLY-OEM-/181749764570?hash=item2a512151da&vxp=mtr
Old Jun 17, 2015 | 01:15 PM
Mackel's Avatar
I'm at work so I can't take a picture of mine.
I found one online but for the life of me cannot figure out how to post it here.
Google Chrysler Crossfire factory tire inflation pump
and go to IMAGES.
The first one on the left, top row.
Old Jun 22, 2015 | 05:31 PM
Goldwing's Avatar
This thread inspired me to check and both cars have complete kits. The SRT6 coupe even has the tool for releasing the soft top. Go figure.
The empty hole on the right holds my manual and a flashlight, or a small flagon of scotch.
Old Jun 22, 2015 | 05:47 PM
The tool that you mention does a number of things besides the soft top release. It is used to remove the lower grille to get at the tow hook and also to release the auto transmission if the shifter gets stuck in park.
Mind you you can pull the grille off by hand and use a ball point pen on the stuck gear shift.
Old Jun 22, 2015 | 08:30 PM
Yes. all that is missing is the air pump.
I assume you ordered the silver wrench that has the 5mm hex for the bow lock, the black one is the standard one that was supposed to be delivered with all roadsters.
I have the silver wrench also, really handy not to have to find the 5mm hex wrench anymore.
BTW. I keep a spare quart of Mobil1 in the right side cut-out.
Old Jun 22, 2015 | 08:42 PM
KDW4Him's Avatar
That is a $100 wrench, you won the lotto!
Old Jun 23, 2015 | 12:52 PM
................. the black one is the standard one that was supposed to be delivered with all roadsters.............
The wrench came with all Crossfires when new, finding it on a new Crossfire was like an Easter egg hunt.
One came with my new '04 and there was one with my SRT. It is mentioned in the owners hand book.
Old Jun 26, 2015 | 09:12 PM
kjwinston's Avatar
As Always guys, nice pictures and advise from you Pros! You guys are the best to help out!
Old Jun 26, 2015 | 11:39 PM
Mrmiata's Avatar
You might want to move that wrench to the glove box.. pretty useless if the top gets stuck and the trunk is locked..
Old Jun 29, 2015 | 09:15 AM
Mackel's Avatar
I'm sure you've already looked for a replacement pump, but if not, here's one I saw in Target over the
weekend that looks like it might fit in the opening for the original...
Air Compressor Slime : Target
And another from the same company that seems to be a little smaller...
Slime Power Sport 12 Volt Tire Inflator | 1 CFM Below Air Compressors| Northern Tool + Equipment
4drturbo
Oct 2, 2015 12:58 PM
ala_xfire
Sep 28, 2015 05:51 PM
ritous1
Sep 26, 2015 01:27 PM
Jackobo
Sep 24, 2015 10:21 PM
maxcichon
Sep 4, 2015 12:50 PM
