TIPS: Using Wrench to Open convertible Manually
Old Jul 1, 2015 | 11:55 PM
cojoman's Avatar
Default TIPS: Using Wrench to Open convertible Manually
Okay guys forget the days of trying to use the special chrysler tool to open your convertible.
Today i decided to explore more and found out the easiest ways to open it under a minute and half. This is always good in an emergency (we all know how our crossfire can act sometimes )
6mm Hench key- $3
10mm Duralast wrench (not really thin) - $5
With the 10mm wrench you should be able to do the same job for this multipurpose tool 5140795AA.
Tried it in my 2005 model and it works great.
Hope it helps someone like me that was going to spend over $160 for that multipurpose key.
Old Jul 2, 2015 | 06:52 AM
Default Re: TIPS: Using Wrench to Open convertible Manually
Or, get an all in one tool for $20 : 2088990080 - Key - ES#1746403
or here : http://mercedespartscenter.com/parts...FQqsaQodesMDpQ
EDIT: ECS Tuning has increased the price, now about $35 including shipping.
Old Feb 11, 2017 | 08:33 AM
cobra1951f's Avatar
The 10 mm wrench needs to have about a 60 degree bend in it to lock onto the nut, just sayin! waiting on the wrench from ECS tuning
Old Mar 30, 2017 | 12:18 AM
Alex's Avatar
Smile Re: TIPS: Using Wrench to Open convertible Manually
Today i decided to explore more and found out the easiest ways to open it under a minute and half. This is always good in an emergency (we all know how our crossfire can act sometimes :rolleyes: )
6mm Hench key- $3
Thanks a lot for the tips !!!
Old Apr 25, 2022 | 12:29 PM
bucker's Avatar
Default Made multipurpose convertible top opening tool for $10
With the manual wrench for opening the convertible top getting near impossible to find I did some online research. Found a 10 MM Park Tool bicycle wrench 1/8" thick on
Amazon Amazon
for $8.50. Needed a longer handle to use on toneau cover so found 8" metal HVAC ( https://www.menards.com/main/heating-cooling/ductwork/ductwork-fittings/double-end-drive-cleats-duct-fitting/70000081lq/p-1444432276904-c-14260.htm?tid=-1381034447118242560&ipos=18about $1. Wrench fits tight into for cavity of the connector , added a little epoxy to be safe and now have a tool that will do what the $150 OEM tool will do for under ten dollars.
Old Apr 25, 2022 | 02:42 PM
Very intuitive! I see you also wrapped it somewhat to prevent paint damage. Awesome!
Old Jun 2, 2022 | 11:27 AM
N2UK's Avatar
I have opened mine with a standard 10 mm wrench with no bend probably 50 times in the last month while working on the car without a battery. A longer wrench would be better, but a standard 10 mm will do the job.
Old Oct 12, 2022 | 11:06 AM
bbrisken's Avatar
Don't laugh, or please feel free... is a 'hench' key the same as a 'hex' key? Signed, so not DIY.
Old Oct 12, 2022 | 11:47 AM
I believe that is a typo, never heard of a hench key.
Old Oct 12, 2022 | 12:29 PM
bbrisken's Avatar
Thanks much ZERACER. Off to AutoZone I go!
Old Oct 14, 2022 | 07:50 AM
Some folks have reported that a 10mm bicycle wrench works great. These are typically a thin wrench and you can get one from Amazon for probably < $10.
AmysXFire
Sep 7, 2022 03:57 PM
Wernski
Sep 8, 2020 06:01 PM
johnbarnwell
May 9, 2020 12:24 PM
Robin Kim
Oct 9, 2018 02:00 PM
sdsantos
Aug 21, 2013 08:39 AM
