Need helps friends
Old Nov 5, 2015 | 02:19 AM
Dak's Avatar
Dak
Default Need helps friends
No battery and I want to open the drunk
Plz. Reply to me
Old Nov 5, 2015 | 09:58 AM
pioneer4x4's Avatar
Default Re: Need helps friends
I assume "trunk" not "drunk", but you will either need a battery hooked up with working key to turn on car, and use the unlock, or a small person to crawl in the back and start tearing it apart. Assuming you don't have a Roadster, then I have no idea. It has a release handle, but I don't know how you would get to it.
Old Nov 5, 2015 | 11:11 AM
Dak's Avatar
Dak
Hhhh trunk, sorry .. it's roadster
And the hook of the soft top stuck !!
Old Nov 5, 2015 | 05:19 PM
Do you have an owners manual? There are instructions for manually operating the top. Try a search on this sight for visual instructions.
Old Nov 6, 2015 | 07:37 AM
Dak's Avatar
Dak
No I don't have one !
And I didn't find semilar to my cause
Thanks for the help
Old Nov 7, 2015 | 04:02 PM
Here is a link to the owners manual and as I said, do a search on this sight "how to manually open a roadster top" and you will see a step by step pictorial instruction.
2005 Crossfire Owner's Manual [24.3MB]
Old Nov 7, 2015 | 04:34 PM
This seems to be the same situation as anpther thread here recently.
The rear bow is latched, and the trunk won't open so you can get the 5mm wrench on the bolt to manually unlatch the rear bow.
I frankly have no answer for this, I thought maybe you could manually unlatch the tonneau cover and raise it enough to sneak an arm into the bow latch, but NO, I tried this on mine and you can't raise the tonneau even one inch.
I am at a loss what to do, other than say this :
REMOVE THE PLASTIC LOCKING THING FROM THE ELECTRIC SOLENOID BEFORE YOU GET IN THIS SITUATION !!!
( See pizzaman's thread on this )
Old Nov 7, 2015 | 10:13 PM
I have heard that you can remove the tag (license plate) lights and trigger the emergency trunk release, but I have never tried this.
I would put a battery in and use the lock system.
Old Nov 7, 2015 | 11:15 PM
Link to Owners Manual. CLICK
Chachi66
Aug 16, 2021 04:24 PM
blackpepper
Oct 4, 2017 06:09 AM
CrossfireZona
Nov 6, 2015 06:21 AM
TiredRetired
Nov 4, 2015 11:23 AM
Rets
Aug 23, 2015 06:31 PM
