Removing Console...Roadster Automatic Trans
Old Mar 13, 2016 | 12:31 PM
Bowman's Avatar
Default Removing Console...Roadster Automatic Trans
I have read the list of repairs and decided today is the day to replace the pesky cup holder with an OEM bin (part #1BQ12XDVAA). As I reviewed the PDF on how to do it, I noticed the images/directions are for a manual shift. My 05 Roadster Limited is an automatic. Does anyone have any suggestions that supplement the PDF... which is for the manual transmission. I am worried about messing up the plate around the shift lever. Also, do I need to remove the shift ****? Thanks, Jim
Old Mar 13, 2016 | 12:36 PM
Mrmiata's Avatar
Default Re: Removing Console..Roadster Automatic Trans
Get advice on disconnecting the air lock line! Did the wife's roadster.. no slack to work with.. did it by "feel" for the torx screws.. Haven't done mine basically for that reason .. LOL
Old Mar 13, 2016 | 01:26 PM
Bowman's Avatar
I read the warnings bout the air line in the PDF. It's the fact that the gearshift surround has more do-dads than the manual. Does the plate surrounding the shift lever just pry loose like with the manual? If so, I'm willing to tackle the task. Heck, I tried to unscrew the shift **** and it didn't budge! Thanks.
Old Mar 13, 2016 | 01:34 PM
You don't unscrew the ****, you unscrew the tapered sleeve just below the ****, then just pull up on the ****.
( yes, I realize I'm leaving myself wide open for jokes here )
The plate surrounds do just pry up, use an interior trim tool.
Old Mar 13, 2016 | 01:47 PM
Bowman's Avatar
I know, it sounds kinda kinky...but I'm willing if she is..LOL Thanks
Arm_and_a_Leg
Aug 13, 2020 03:12 PM
TommyT
May 31, 2017 12:54 PM
Rob M
19
Jun 16, 2016 01:12 PM
carmjr1
Mar 27, 2016 01:23 PM
Dave F
Mar 15, 2016 05:03 PM
