Part number and source
Old Apr 20, 2018 | 02:48 PM
crazyfred's Avatar
Default Part number and source
Would anybody happen to know the part # for the throttle position sensor and a source for getting one?
Thanks in advance
Fred
Old Apr 20, 2018 | 02:51 PM
Default Re: Part number and source
There is no such thing.
There is a position sensor inside the throttle pedal assembly, and also one inside the throttle body.
Neither can be obtained without buying the assembly.
Old Apr 20, 2018 | 03:15 PM
crazyfred's Avatar
Thanks ala-xfire
I'm having an issue when doing a wot push and the gas pedal, the throttle is non responsive until you turn the car off and restart. Th e consensus is that the throttle position sensor is bad. I did see where you had to get the whole pedal assembly. But how can I determine if the pedal assembly is bad or the throttle body sensor is at fault?
The code I'm getting is po123
Tps pedal position sensor a circuit high input.
Thanks for responding and thanks for your help.
Fred
Old Apr 20, 2018 | 04:22 PM
with the P0123 it's most likely the pedal assembly.
danimal
Mar 7, 2010 11:42 AM
stevenjames
Jul 11, 2006 01:13 PM
04Roadster
Dec 28, 2005 12:55 AM
respdoc
Jun 30, 2005 05:46 PM
Alon
Jun 17, 2005 04:35 AM
