Found source for top tool < $25
Old Apr 28, 2018 | 03:13 PM
Default Found source for top tool < $25
This is the combo tool ( includes hex bit for the bow latch )
https://www.ebay.com/itm/Mercedes-W2....c100284.m3505
Old Apr 28, 2018 | 07:28 PM
S8MS-01904's Avatar
Default Re: Found source for top tool < $25
i bought one of them last year. You will need to cut 1 1/2" off the hex end to make the tool easier to use. The dremel with cutoff wheel did the trick.
Old Apr 28, 2018 | 08:03 PM
1 1/2” seems a bit much.
Old Apr 30, 2018 | 04:34 AM
JACxf's Avatar
I need to either buy or fabricate one of these, and for <$25 I cant see the point in fabricating one.
So, does it really need 1.5" cutting of the hex head?
(and thanks for sharing ala_xfire)
Old Apr 30, 2018 | 06:29 AM
S8MS-01904's Avatar
Your best bet is to get the tool and try it out first. The one I received was too long to maneuver into position. I simply cut half off and now is a whole lot easier to use.
Old Apr 30, 2018 | 06:49 AM
JACxf's Avatar
I have ordered one, ETA 6th to 10th of May.
Old Apr 30, 2018 | 06:50 AM
Buy a tool that you need both ends and then saw it in half or just cut 1 1/2”, only one can be correct.
Old Apr 30, 2018 | 06:56 AM
JACxf's Avatar
Well, that depends, if the hex part is 3" long, then you may saw that part in half and remove 1 1/2" at the same time
Old Apr 30, 2018 | 01:23 PM
That makes sense.
Old Apr 30, 2018 | 01:49 PM
The hex bit on there DOES look awfully long. I use the factory tool and carry a hex key and I remember that the key just about fits and the 'elbow end' is maybe an inch long.
Old Apr 30, 2018 | 01:50 PM
39 sold, 3 left as of one minute ago.. Typically, they go FAST when they pop up somewhere.
Old Apr 30, 2018 | 08:47 PM
S8MS-01904's Avatar
Yes, the hex part is too long. Shorten the hex bit to your liking.
HTuller
Feb 20, 2018 09:26 PM
ala_xfire
Aug 10, 2016 02:08 PM
harbor
Aug 19, 2009 09:14 AM
larbo53
Jun 8, 2009 02:54 PM
MikeL38
Nov 15, 2007 02:14 PM
