Help with soft top swap
Old May 10, 2018 | 10:11 PM
customcover's Avatar
Default Help with soft top swap
Currently in the middle of a top replacement. Have a problem of getting the side rubber window molding back in place. They where hard to get out, but can’t seem to get them to stay in place. Any suggestions?
Old May 11, 2018 | 07:46 AM
Default Re: Help with soft top swap
Yes. When you extracted them, you expanded the channel within the rubber piece.
I use channel lock pliers to GENTLY compress the channel back down until it is almost closed along the entire length of the strip.
Then I use a wooden mallet to seat them.
BE CAREFUL OF HITTING THE SWITCH ON THE PASSENGER SIDE !!!!!
You must be the king lurker on here - member for 6 years and only 2 posts.
Old May 11, 2018 | 08:32 AM
Iamfink2's Avatar
When i replaced mine I used some soapy water to help them slide in easier after doing what ala_xfire described to do to make them fit.
Old May 11, 2018 | 08:38 AM
All out of Vaseline huh Pat ?
siataukreg
Europe
Nov 22, 2008 05:24 PM
lu8
Northwest Forum
Jul 29, 2008 05:01 PM
etmusic
Jan 28, 2008 01:37 PM
MikeL38
Nov 15, 2007 02:14 PM
SteveB1
Detail Shop
Apr 23, 2007 12:09 AM
