No fuel in the injector rail
Old Oct 27, 2018 | 06:23 PM
Jefwder's Avatar
Default No fuel in the injector rail
2005 standard shift roadster. 16,000 .org miles. Car failed to start one day just cracked over with no fuel at Injector rail. Towed to dealership and when it got there they turned the key and it started. Put the diagnostic unit on and no fault codes found or registered. One employee actually said maybe you didn’t push the clutch pedal in far enough! WT!!! Car ran like a dream all summer and just quit again. Read all the posts. Replaced fuel pump relay with new OEM board and replaced the crank position sensor for good measure. Got in turn it over but still same issue. Fuel pump runs, engine cranks still no fuel to injectors
ideas and thoughts
Old Oct 27, 2018 | 06:48 PM
waldig's Avatar
Default Re: No fuel in the injector rail
Fuel pressure regulator is suspect. Woody
Old Oct 28, 2018 | 11:24 AM
Fuel pump motor can run and still no pressure. Sounds like time for new pump and filter that contains regulator.
Old Oct 28, 2018 | 11:39 AM
How did you decide there was no fuel at the rail?
The fuel filter would be a cheaper fix than doing the pump as well, the car has few miles on it.
Old Oct 28, 2018 | 04:47 PM
Jefwder's Avatar
There is a shredder valve on the rail I released it and no fuel came out. Bad assumption?
Old Oct 28, 2018 | 04:50 PM
There should be some pressure there during and a while after the pump runs. The car may have few miles on it, but it is still aged.
Old Oct 28, 2018 | 06:58 PM
waldig's Avatar
Yeah the schrader valve should pee gas, the filter could also be massively clogged up, Woody
Billy22Bob
Jul 9, 2012 04:00 PM
tunaglove
Dec 16, 2010 09:52 AM
ImportLabSRT
Dec 16, 2010 08:10 AM
HDDP
149
Aug 22, 2009 02:15 PM
