adding top fluid
Old Oct 30, 2018 | 05:10 PM
Default adding top fluid
I believe the easiest way to add fluid to your top reservoir is to remove the driver side trunk panel, remove one screw from the controller and move it aside. You must pull up on it to remove it. You then have easy access to the plug and easy access to add fluid. A turkey baster and plastic hose works well. This is much easier thay trying to reach down through the top cover cover opening.
SeaShark
Feb 5, 2015 10:32 PM
cuziamninja
Apr 8, 2014 02:22 PM
MRethman
Feb 15, 2014 07:09 PM
TopHydraulics
Mar 15, 2013 11:20 AM
x fire ron
Aug 18, 2012 10:37 PM
