Alarm going off while driving
Old Apr 3, 2019 | 04:33 PM
Dantedog's Avatar
Default Alarm going off while driving
Just got my 05 roadster and was driving down a city street when the alarm went off. This has happened twice. I pull over, turn the car off and hit the lock button and it turns off. What could be making this happen?
Old Apr 3, 2019 | 04:44 PM
Default Re: Alarm going off while driving
Corroded batteries in your alarm siren. Time to replace. It is located under the windshield cowl. Very common problem since the cars are now over 10 years old.
Here is some info on the subject https://www.crossfireforum.org/forum...king-pump.html
James
Old Apr 3, 2019 | 05:37 PM
Dantedog's Avatar
James
Thank you sir much appreciated.
Old Apr 8, 2019 | 05:12 PM
Dantedog's Avatar
If I replace the siren will that fix it? Are the batteries part of the overall unit?
Old Apr 11, 2019 | 06:50 AM
Doverhahn's Avatar
Yes, that will fix the problem.
The alarm module has 2 small batteries of its own.
If you have changed the alarm and open it upby using a saw, it probably lookjs like this.
To get to the alarm module, you have to take of the windscreen wipers, than the black cover.
When doing that anyways, also clean the small waterhoses that take down rain water from that area and take out all leafs and other debris.
Good luck
Alwin
Old Apr 11, 2019 | 08:58 AM
Make sure you don't push any of the drain hoses off their nipples when cleaning, if you do, then you are screwed dude
Cedar11
Sep 23, 2014 07:37 PM
Louie K
20
Jul 14, 2011 11:27 AM
WesMichaels
Oct 11, 2010 03:46 PM
blkXfire04
Oct 27, 2009 06:03 PM
