ISO Convertible Top Pump and Motor Parts
Old Jun 3, 2019 | 01:37 PM
Waterwren's Avatar
Default ISO Convertible Top Pump and Motor Parts
Hello! Have a 2005 Limited Roadster Convertible and need to replace the convertible top motor and pump. Can anyone recommend a place to buy replacement parts? Dealer says we need: Mercedes part #A11938000048 and Mopar #5142638AA. Dealer wants to charge $800 for parts and $270 to install. Looking to lower the bill by finding our own parts. Any help will be greatly appreciated. Thanks!
Old Jun 3, 2019 | 02:01 PM
Default Re: ISO Convertible Top Pump and Motor Parts
I would try E-bay. What exactly is your top doing, not doing? I wouldn't trust the dealer.
Old Jun 3, 2019 | 02:08 PM
You took the car to a dealer and now you need a new pump? I've been a part of this community ten years, owned three Roadsters, never seen a pump go bad.
Sounds like typical dealer lack of diagnostic ability: "Its a complicated Mercedes system, we do not know anything about how it works, we don't know how to do diagnostics - so, lets throw expensive parts at it until it works".
I'd bet next month's rent that once you replace the parts, it still won't work. As you were asked above, what is it doing or not doing?
Read my sigline.
Old Jun 3, 2019 | 07:58 PM
Waterwren's Avatar
What it’s doing: When the back window folds towards the back seat and the convertible cover comes out of the trunk, the cover runs into the top and you have to pull the top forward to let the cover go past. When the convertible top folds down into the trunk, it hesitates as if it doesn’t have enough power to pull it down into the trunk. The motor runs intermittently and revs higher and you have to gently push it down into the trunk. When you put the top up the back window doesn’t latch completely and seal the window against the body.
Old Jun 3, 2019 | 09:24 PM
KeithTexas's Avatar
Have you had to add any hydraulic fluid to the pump reservoir?
Old Jun 4, 2019 | 10:43 AM
It does sound like low fluid. Do a search on this site and find lots of info.
Old Jun 4, 2019 | 11:02 AM
Sure sounds like low fluid to me, too.
Old Jun 5, 2019 | 10:27 AM
Waterwren's Avatar
Many thanks to everyone who has responded, I appreciate your time and recommendations! I have been searching this site for more information or better yet, a video on how to remove the trunk trim to access the hydraulic reservoir. Saw a post from pizzaguy that says fill level should be half full and is correct amount because it will show higher once the top is done moving and the pressure is released. So if my reservoir is low, only fill to half full? Also, is Pentosin CHF-11S the best hydraulic fluid to use?
Old Jun 5, 2019 | 02:00 PM
There is a fill mark on the pump tank, and yes Pentosin CHF-11S is the correct fluid.
Use a turkey basting syringe.
Old Jun 5, 2019 | 02:06 PM
KeithTexas's Avatar
I'll let the experts chime in on details. My top wasn't working when I bought my car. I tried adding additional Pentosin fluid. I could see a glimmer of life in the movement of the top, but it stopped immediately and I could see hydraulic fluid had leaked from the two main lifting cylinders. I took those two off and sent them to Top Hydraulics for rebuilding. Everything worked perfectly after I got the two cylinders back and reinstalled them and filled the reservoir to half-full. Haven't touched it since then.
As Pizzaguy has often said, the hydraulic fluid is not consumed and doesn't evaporate. As a result, if you're low, there's a reason.
PNA
Oct 30, 2012 10:54 AM
AGeddy
May 25, 2011 09:59 AM
tarmacevo
Apr 4, 2010 09:42 PM
Doyen
Mar 25, 2010 02:56 PM
Electric Messiah
Aug 13, 2008 10:57 AM
