Roll Guard removal
Old Sep 25, 2019 | 02:44 PM
Hans3232's Avatar
Default Roll Guard removal
Does anybody out there know if it is possible to remove roll guard from crossfire convertible. I need to remove passenger side so my homecoming queen granddaughter can ride back there in homecoming parade.
Old Sep 25, 2019 | 04:08 PM
Default Re: Roll Guard removal
I believe they bolt to the rear bulkhead through the trunk area. There may be some good info here.
https://www.crossfireforum.org/forum...#&gid=1&pid=13
Old Sep 25, 2019 | 11:39 PM
UrbanE's Avatar
Use cation
I’ve taken that area apart a few times.
I wouldn’t recommend removing it and more importantly, once you look inside the area you’ll come to the immediate conclusion that having some one sit on that area is a sure fire way to ensure your top never works again.
Old Sep 26, 2019 | 03:14 AM
Before removing a safety roll bar, maybe you should either let her stand up OR place a few towels/mats on seat to stand on. Sometimes, removing safety equipment results in not putting them back after a special event. There must be not enough room to sit in between then (at slow speed) or you would let her sit centered there (on a few blankets/pillows)? You wouldn't want it (roll bar) missing when needed, would you? Good luck (maybe a different vehicle?)!
imported_mightyjlr
Detail Shop
41
Jan 1, 2016 10:16 PM
Coach K
Apr 15, 2012 09:46 PM
midlife chrysler
Detail Shop
22
Sep 11, 2009 11:18 PM
tlb44
Aug 17, 2003 05:45 PM
Diamond Jim
Detail Shop
Aug 13, 2003 05:17 PM
