Cover manual access?
Old Feb 25, 2021 | 09:50 PM
No704's Avatar
Default Cover manual access?
Anybody ever make an access hole between the seat backs to get to the manual tonneau cover bolt?
Old Feb 25, 2021 | 10:11 PM
Default Re: Cover manual access?
I don't see how you would do that without drilling thru the gas tank!
So, what's going on? Why would you need to do that?
Old Feb 27, 2021 | 03:35 AM
No704's Avatar
Makes sense now, I had thought the tank was lower than that.
Need to fix a couple leaks in the hydraulic system. With this Covid sh*^+ paychecks can be a little spotty.
Thinking I’ll just operate it manually for a bit.
Old Mar 1, 2021 | 09:39 AM
I think you are forgetting how low the gas tank is.
Old Mar 2, 2021 | 02:14 PM
ANYONE who is going to drill thru that bulkhead has better know EXACTLY where the tank is.
But again, I still dont understand what the OP was thinking, there is no use or need in drilling thru the bulkhead that I can see.
Old Mar 2, 2021 | 05:49 PM
No704's Avatar
I have yet to try the long thin wrench, but it looks like a pita. Thought it might be easy to make a hole for a socket.
Old Mar 2, 2021 | 06:31 PM
What exactly are you trying to do?
Old Mar 2, 2021 | 08:54 PM
The system is designed for manual operation, it's easy. Drilling holes in the car is not going to help.
Old Mar 3, 2021 | 12:51 PM
CROSSFIRERUSH's Avatar
Mark, Dave and No704,
A picture is worth a thousand words. The gas tank appears low on that bulkhead. This pic is of a coupe but I'm sure the convertible is similar.
No704, just get the tool and practice a couple of times following Mark's video. Really nothing to gain drilling a hole through the bulkhead.
Regards,
Old Mar 3, 2021 | 05:38 PM
No704's Avatar
Thanks for the replies, I’ll buy or make a wrench. Anybody have a preference on the strait vs angle head ?
Old Mar 4, 2021 | 01:12 PM
I don't see how the strait version work, but Ala_xfire (George) says it does..
Tagging @ala_xfire
Old Mar 4, 2021 | 03:49 PM
There were two standard wrenches supplied with the car, one came with a straight 10mm opening and the other with an angled 10mm opening.
I have had them both. I could possibly dig out the Mercedes part number for each.
Old Mar 4, 2021 | 03:53 PM
Tagging @ala_xfire
You are correct ( I think ) Mark.
I thought I had the straight version, but upon closer inspection I find I have the 45 deg angle version.
The part number is A2088990080
https://www.ebay.com/itm/303275043403?chn=ps&norover=1&mkevt=1&mkrid=711-117182-37290-0&mkcid=2&itemid=303275043403&targetid=10683238583 50&device=c&mktype=pla&googleloc=9012851&poi=&camp aignid=11755691403&mkgroupid=117768900681&rlsatarg et=aud-622524042918la-1068323858350&abcId=9300462&merchantid=115340227&g clid=CjwKCAiAp4KCBhB6EiwAxRxbpHVVuj-zpdM-50nDVrBT76630mfEqTvZXvjwUkDcleXO6YuXZuVlfxoCwREQAv D_BwE
Old Mar 5, 2021 | 05:32 PM
The best tool to have. It has the 6 mm Allen key fixed to it.
What I call the straight and angled tools, one or the other came with the car originally.
The 10 mm wrench end is not required om the coupe nor is the other end as it can be replaced by using a screwdriver.
Old Mar 5, 2021 | 07:13 PM
Dave, I agree the best tool is the one with the hex key.
But I gotta say, I have had three Roadsters in eleven years. All three came with the upper tool in the picture, but not the lower tool.
I'm dumbfounded to learn that some/all cars came with both, after being a member here eleven years.
EDIT: I misread your post. And I went out and looked, the SE came with the bottom tool. My Limiteds, at least the Graphite, came with the upper tool.
Still learning after eleven years....................... (And I'm ten posts from 11,000!)
Old Mar 6, 2021 | 12:07 AM
JSK's Avatar
JSK
Neither of my roadsters came with a tool. The one I bought first was the one without the Allen head. The second had the Allen on it. I think the one with the Allen is best, if I needed a flat blade screwdriver I bet I could find one.
Old Mar 6, 2021 | 12:33 AM
Here might be another, less expensive ( https://mercedesbenz.worldoemparts.c...p-208899008064 )?
Old Mar 6, 2021 | 09:49 AM
I am 300 posts from 24,000, lots of them inconsequential.
I could not find a wrench on my brand new 2004, so I asked the dealer for one, it was taken from another Crossfire. Some time later I found the original wrench in the pocket between the seats, so I had two. I gave one away to someone who never got one. I have never used it.
ZX2 Nick
May 21, 2018 10:02 PM
jwizardtree
Sep 5, 2016 12:10 PM
randyradio
Jan 17, 2013 01:40 PM
etmusic
Mar 2, 2012 12:12 PM
BRappaport
Jul 22, 2009 10:12 AM
